Battery Disconnect
markusaf81
So I’m getting ready to swap out my radio and I know I need to disconnect the negative cable from the battery.
I have an aftermarket remote start (Doug from eBay) and I have a diablo tuner, will disconnecting the battery mess either one of these up? I wouldn’t think so because both flash the PCM, just double checking.
I know my remote start came with a warning label saying something about truck may start if battery is disconnected and connected.
Ramitiner
U.S. ARMY VETERAN
NJ
I really doubt that would be an issue bud
NoMPG2010
Should not be an issue. disconnect and good luck with the install.
markusaf81
markusaf81
The remote start doesn’t work, I emailed “Doug” to see if I need to reflash the unit.
JinxCanada
Windsor, Ontario, Canada
2010 Ram Sport
maybe a stupid question...but why do we disconnect the negative instead of the positive terminal on the battery? or does it matter?
markusaf81
markusaf81
That I don’t know, just googled it and it was the first step
You disconnect the negitive terminal first to prevent a direct short if you loosen the positive terminal and touch ground with the wrench.
KansasArt
Kansas
Omg, that brought back a bad memory! I did that, touched the frame with the wrench while loosening the positive nut. A wrench can carry a great amount of current and makes a pretty blue flash!! Disconnect the negative first, always!!
