Battery drain
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
There is no such animal as a spare 10mm socket or wrench. At least not for more than one or two uses of the original, then what was the spare becomes the primary and you have to start over again. :emotions122:
That's why I keep a spare in the safe right next to my 1911. :cool:
RamDiver
Marlborough, Ontario Canada
2021 DS
Calling it a spare seemed easier than identifying it as, loose in a drawer with a bunch of other miscellaneous-sized wrenches. Loose and mixed wrenches versus part of a set.
The same goes for the stubby ratchet, it rarely gets used, I may as well store it in my truck.
The extension was loose in the back of a drawer too and the socket came from an old ratchet set that hasn't been touched in years because I have other sets.
You know, we all likely have these extra bits in the backs of tool drawers.
Curmudgeon
York, Pennsylvania
Do you take them out occasionally and give them a good polishing? You know, so they know they're loved and not forgotten.
Quite the opposite, I hide it under the foam rubber.
Never make eye contact with a 10mm. It is a form
of aggression, causing it to flee.
J
Juls
Wisconsin
Well folks, here we go again! Truck died again. Same issue! I took yet another video and pictures of the dash lights. So, tomorrow morning they will be getting a call from me. I can’t imagine that this is good for a new battery. This will be the third recharge after it is drained.
RamDiver
2021 DS
That's most unfortunate but not too surprising.
I would urge you to never return to that dealer, find another local mechanic that has good reviews, or find a helpful friend and get help here on the forum, if you have the time.
That dealership sounds very incompetent, will just keep taking your money, and may never get this fault repaired.
If the noise has returned while the key is off, start pulling the fuses we identified earlier. Once the noise quits from a fuse extraction, you will learn what component is eating batteries.
Leave the fuse out and get a low-current (2 Amp) battery minder/charger onto the battery before it expires.
Marshall
Sk, Canada
2014 sport
I don't have a air ride, so I can't really add much. I guess the air pump must be live to battery even when truck is off?? strange/ stupid I would say.
There has to be a air leak in the pump, or a bad air line or connection.
Or a air bag shot. Or??????????
Should not be that hard to track down, with the truck up on a hoist.
Soapy water on all the connectors use to be the way we found air leaks.
Curmudgeon
York, Pennsylvania
Here again, it depends rather heavily on the mechanic...
J
Juls
Wisconsin
I didn’t think it would be that hard either. You would think my video and me showing the mechanic would give him a lead to what is going on!
DudeWalksOnWater
Canada
My 2020 RAM would not start. Nov. 27, 1023 I put in a new battery. On Dec. 14,2023 my truck wouldn’t start. When I looked under the hood I could hear something running. It would alternate between a high pitched noise and a sshhhhhh noise. I did video the issue.
It has been at the dealership for weeks. Still no solution. Any help is appreciated.
Do you have the air adjustable suspension. Sounds a lot like the compressor kicking in.
10mm & 1/2" wrenches of every type, can be found where you hid the 5.5 mm allen wrenches.
Find a local Auto Electric Shop, they still have old style
Parasitic Drain Tester​
how to ..
J
Juls
Wisconsin
Yes I do.
FYI- I picked up my truck. The serviceman told me that the new battery had a bad cell. Well, I did tell them when I had it towed there that it was a new battery and I had contacted NAPA in case they needed to replace it. I was told by the serviceman that it is unlikely it is the battery, it’s new. I told them to check the battery. After repeated charging it continued to test low after a few days. So they replaced the battery under my battery warranty. We shall see if that does the trick. PS. They did not charge me for labor for the second time it was in there.
