Dan Topp
- Joined
- Aug 14, 2019
- Posts
- 1,369
- Reaction score
- 2,738
- Location
- Jefferson Wisconsin
- Ram Year
- 2019
- Engine
- 5.7
First time I opened the hood since it was at the body shop and have a lot of cleaning to do.
Mine lasted 2 years and had to replace at $548.00. Stupid high price from dealer.How long are your batteries lasting? I'm on year 5.5 with original battery, about 65k miles on the truck, voltage is at 14.9 while driving.
Should I replace it now before it leaves me stranded some day?
Sorry, but you missd a few points.Later Challengers don't lose station presets or the clock,the only thing they lose is the equalizer settings.Are you sure your 09 loses the radio presets. I'm going to have to check with my buddy,as he has a 09 SRT Challenger with only 18,000 miles on it,and he disconnects the battery every winter,and i don't remember him ever saying it lost the radio presets,but then again,i've never specifically asked him that question.
If something is going to sit for several months,i don't see any advantage to keeping all the modules alive during that time.Maybe somebody can point out the advantages to keeping everything energized for several months of non use,as i don't see any advantages to keeping electrical components energized if you're not using the vehicle for several months
FLAPS price for mine - when I bought it a few years ago - was around $250. No idea what Bidenomics has driven them up to since then.Mine lasted 2 years and had to replace at $548.00. Stupid high price from dealer.
If you had that covered on warranty, no problem. If you paid that out of pocket you have way too much money. I can get a group 27 with 4 year full replacement and 52 more months of prorated coverage for 190 bucks even here in Canada and we aren't known for our low prices.Mine lasted 2 years and had to replace at $548.00. Stupid high price from dealer.
And just how many of those vehicles have electrical issues.Why would keeping the electrical system energized make any sort of difference? Isn't that what cars used as daily drivers do all the time?
And who's to say applying voltage to connectors that have sat unused and dissimilar material corrosion has had a chance to work its magic will not cause problems? lolAnd just how many of those vehicles have electrical issues.
If it's not powered it can't burn out,lol
They'll corrode from dissimiliar metals faster if there's power passing through them.And who's to say applying voltage to connectors that have sat unused and dissimilar material corrosion has had a chance to work its magic will not cause problems? lol
Original battery in my 1994 V-10 2500 4wd lasted 12 years. The one in my 2003 V-10 2500 4wd lasted 11 years. The battery in my 2017 RAM 6.4 3500 4wd died this month. Hate to think how long it will last in my next truck.
Does he also put the car on stands to avoid flat spots on his tires? That saves as much wear as disconnecting the battery.They'll corrode from dissimiliar metals faster if there's power passing through them.
Capacitors last alot longer if you're not passing any power through them.
Face it Bob,there is no advantage to keeping the battery hooked up,if you're not using the car on a weekly basis
You must think nobody else knows how to store a vehicle with that question,of course it's got the suspension unloaded.Does he also put the car on stands to avoid flat spots on his tires? That saves as much wear as disconnecting the battery.
The advantage to removing power is minimal at best.
Like almost everthing else in life, it's a choice. You and your buddy have made yours. I've made mine. I won't convince you, you won't convince me.
Call it a draw. I'm sure some members are a bit annoyed with the constant back and forth.
What the hell are you talking about Dude. I didn't make no snide comments,if anybody was making a snide comment,it was you.Oh fer....
Give it up. Snide comments aren't winning any points.
I'm done. Please move on.
This brand new 2024 Ram GT battery dies anytime it goes below zero over night.. made me miss work a few times now...and 2 of those were trioke time unfortunately....How long are your batteries lasting? I'm on year 5.5 with original battery, about 65k miles on the truck, voltage is at 14.9 while driving.
I just replaced my battery in my 2018 RAM 1500 ONLY because it would no longer hold a charge. Carry a battery power pack jumper for less than $60 and keep using your existing battery.How long are your batteries lasting? I'm on year 5.5 with original battery, about 65k miles on the truck, voltage is at 14.9 while driving.
Technically an AGM is still a lead/acid battery,you might not want to use it on some of the lightweight lithium batteries that are big in the racing worldSo I just picked up this noco jump starter, it says "safely jump start dead batteries on most gas vehicles up to 6 liters" so I bought it. Opened it up and the fine print says "only use on lead acid battery chemistry"
Is that something I need to take seriously? And what chemistry do I have in a stock 5th gen, I thought we moved away from lead acid years ago?
