BCM
ponchog
delaware
i have a 2013 sport 1500 with factory led lights, im getting a left turn signal hyper flash on my dash with a message left turn signal out, but everything works fine on the outside all lights work and flash as they should, the dealer said its the BCM, question can i use a used BCM and also where is the BCM located. dealer wants 600.00. thanks
buddy guy
alberta
the body control module is to the left of the steering wheel under the dash. if you get a flashlight and look up from your parking break you'll see the panel. it has a lot of connectors. hard to get at the damn thing. i think it would be a pain to replace myself. 600 bucks is insane.
Raadz
