Bds 4 corner suspension help
codyzilla
So I bought an eco diesel and later found out it already had the bds lift on it. I drove it a little hard and popped a fitting off the top of the bag. Replaced it for a metal one instead of the plastic one bds gives you then it was all good. Then took it for some light slow speed off roading and almost to the end the opposite side fitting came off. So I was stuck on the trail got out replaced it for a cheap one for now and now it is driving like absolute crap. I can't imagine that this lift would be that ******. And when I back up and turn there is a popping bows from the front. Can anyone else at all. I'm new to this and I can imagine I'm in the wrong place with this questions but please help. Tempted to just trade it in for a 2500 now
xrsman
Ontario
3.0 Ecodiesel
Hope you get it all sorted out.
Sent from my SM-G930W8 using Tapatalk
pitajr
Niagara Region Ontario
back up turning sound could be tires rubbing? are the tires over sized from stock? bds air lift supports up to 35 inch tires but all depends on the offset of the rims
chesafreak
2016 Sport Crew
Did you get the tank refilled after replacing the fittings. Between the initial lift unplugging the fittings and replacing 2 fitting you may be low on air.
68Cudaconvert
