Bed lighting
chris61530
US
I installed the oem bed light kit. I've also the oem switch. I got the lights working, does any one know how to get the switch to work? I found another connector next to the light connector that it will plug into. Is there anything else I need to do?
Thanks for the help!
Sent from my SM-G975U using Tapatalk
C
chris61530
US
Forgot to mention this is an 18 2500
CincyCuda68
Ohio
When you get everything working can you post a how to, may help someone looking to do the same thing.
Inside Man
N.E. Ohio
Everything should be plug and play. Then you have to get the dealer to open the sales code in the computer.
Or us the Alpha to do so.
C
chris61530
US
I did use alpha and they do work with the cargo light, what I'm trying to do is to get them to work with the oem bed switch as well.
Redheadhunter21
SFL
On my truck the two wires for the cargo switch were tapped up and capped with heat shrink. They were on the drivers side harness going toward the bed light connector. I was able to buy a connector online so it would look factory and allow easy bed removal if needed.
I had the sales code added before I had alfaOBD and once connected it worked with no issues.
C
chris61530
US
This is the kit from Amazon Dodge Ram 1500 2500 3500 Cargo Bed Light Installation Kit Mopar OEM Part#82214870AB and the switch is part #68367545AA from buymoparpartsnow.com
Inside Man
N.E. Ohio
Lol man of few words, do you have a link or a reccomendation on where to purchase.
Yes please post a link or part number
Sent from my SM-G950U1 using Tapatalk
Sorry guys. Busy weekend.
As chris61530 stated, look for the Mopar Bed Lighting kit.
I believe 2016 and up already have the mounting holes for them in the bed as well as the wiring harness plug in's around the taillight area under the bed.
When the sales code is activated they will light up along with the white cargo lamp bed lights activated by the factory cargo lamp button.
https://www.amazon.com/Dodge-Cargo-Light-Installation-Mopar/dp/B01C3DJ0NY
CincyCuda68
Ohio
Thank you, that will help people out.
Any luck with the switch?
Inside Man
N.E. Ohio
No switch needed If you don't want it from what I understand. Should operate by the factory cargo light switch and work in conjunction with the cargo lamp third brake light.
Also to be clear, I've only researched these and I do not have them yet. I'll be pulling the trigger soon however I can not speak from experience.
C
chris61530
US
No switch needed. Should operate by the factory cargo light switch and work in conjunction with the cargo lamp third brake light.
That's correct it works with the cargo lamp switch, I'm trying to get the bed mounted switch to work as well.
Inside Man
N.E. Ohio
Ok, my apologies for the misunderstanding. I'll be watching this closely
CincyCuda68
Ohio
No luck yet
Damn, I would think there is something in alpha other than what you’ve already done. I’ll try to scroll through and see if I find anything, can you post what you changed so far?
@1500ram12 and @Jimmy07 are pretty good with alpha, maybe they may have an idea.
C
chris61530
US
The only thing I saw in alpha that pertained to the bed lights was "truck bed lightning feature=yes"
Jimmy07
I do remember one other guy trying to get the switch to work- @SRich2015. The highest year the alfa *actually* supports is 2017. That switch circuit (L26 on the C6/F BCM connector) didn’t exist on 2017, so there’s nothing there for the alfa to enable.
joshhhh
