Belltech 2/5 drop 04 ram allignment issues
DFWHEMI04
I did the 2/5 drop with springs in the front and flip kit in rear. The shop could not align the truck properly. the top of the tires are bowed inwards. Can anyone give me some pointers?
Red_Sled
Alabama
4.7L Magnum
Have you upgraded your control arms? I am no expert, however, I do know with stock arms you can't adjust the camber too much
I-II
BFE
Here Moog Alignment Caster / Camber Kit. With this kit you can adjust your Camber Plus or Minus 1 Degrees; Caster Plus or Minus 1-1/2 Degree(s). I had to put this on my 2wd 03 with a 2 inches dropped on the front.
Also with that drop you'll want to get those bump stops out of there.
