Didnt have luck with the Mobil 1 here in Venezuela so I went with Valvoline 5W20 sytn.
Is it normal to be smoking ?
(guys bare with me because I just got the truck and this is my first oil change)
Its smoking when I accelerate and its smoking quite a bit. Can it be because of the other oil that it had? It was a semi syt and now I went full syt.
Did you make sure you put a little fresh oil on the oil filter gasket before installing it? Did you over tighten the filter and damage the oil filter gasket? The gasket off the old filter was not still on the oil filter adapter, was it?
Smoking only when you accelerate and it not having done it prior to the oil change leads me to believe it is filter related.
So this morning I looked all over and even a drop of oil.
Can this be because of the Oxygen sensors that I need to replace? what I dont understand is that before the oil change wasent smoking
