Gauge Widget on 1500 Limited
rockingreno
Louisiana
I just purchased a 1500 Limited and programmed my screen widgets and added the gauge options. Problem is, when I first added them they showed Oil Temp, Trans Temp, Water Temp and Brake %; however, now it is just showing the gauges with no data. Has anyone else had this issue. I've deleted the widget and added it back, added on different page of the home screen and still no data. Any info would be appreciated.
Thx in advance
Dean11
Ca
Did you ever get a answer? Same problem as me.
sigfla
I have a 2023 and no widget at all for gauges. Can any of you tell me what options you have that includes it? I thought for limited trim in 2023 it came standard
Pastor Bob
Carthage Mo
Where are you looking for the widget? There is a button on the left side of the steering wheel that will pop up a whole new screen on the dash. This can be customized to show all the gauges you want to see...oil pressure, tire pressure, voltage, etc.
commander
Myrtle Beach S.C.
2024 1500 Limited Crew Cab
Anybody get it figured out yet? I have a 2024 Limited, Dealer reset the radio, worked every day for a few days, then quit altogether. I'm thinking may be a bad connection.
Gauges have not worked in two days, but today, they were working! Sporadically as has been stated. I will see what tomorrow brings.
JT
skates15
Ohio
I configured my screen with the gauges as well. They won't display any readings until the temps are up. I don't know if this is by design or not.
Its been useful in monitoring trans temps to determine if I will install a thermal bypass to lower temps.
skates15
Ohio
OP is referencing the gauge widgets that you can add to the media screen. On my 12" head unit I edit the main screen and placed the gauges in the lower half of the screen.
commander
Myrtle Beach S.C.
Skates15, Yes, they only work when temps come up, but driving for 30+ minutes, they are blank. They will work for a few days in a row, then nothing. Almost acts like a bad connection or electronic component in something.
commander
Myrtle Beach S.C.
Update! After NOT working for 4 days, they all of a sudden are working again, and for the last 3 days. I'm almost convinced it's a loose connection. I have not been back to the dealership, as when I'm that way, and think about it, they are working! Frustrating as heck.
JT
commander
Myrtle Beach S.C.
Well, back to not working again, even the trailer brake gauge is not working when I hit the brakes. Dealer tried "resetting" the radio unit, only worked a couple days.
Glowz
