Best way to heat a cab on cold mornings
Chucky33
Cummins 6.7
Does anyone have good advice on how to get the cab warm on cold mornings with a Cummins 6.7 diesel
Power247
High Point, NC
6.4 HEMI
Do you use the block heater??
Greg
2012 | 2500 | CCLB | Custom MCC by Double R Diesel
Donnieram2012
Diesel 6.7 liter
I actually tried one of those Mr heaters work pretty good but be careful you can burn your truck up!!
C
Chucky33
Cummins 6.7
No I just bought the truck and did not realize they would not have a block heater as standard equipment
C
Chucky33
Cummins 6.7
Cab , I normally start the engine early but the cab don't get warm and my defroster don't get warm until I drive a couple of miles.
Power247
High Point, NC
6.4 HEMI
Look inside the the bumper opening on the passenger side. If it came from the dealer with the cord it will be clipped up inside. If the cord is not there you can order one online.
Greg
sbarron
Wasilla, Alaska
You'll have to look at your build sheet to see. Or look on the truck for the plug. Sometimes it's ******* right behind the passenger headlight.
C
Chucky33
Cummins 6.7
Greg
Thank you I found the plug after you told me exactly where to look.
Power247
High Point, NC
6.4 HEMI
No problem bud. Make sure you unplug it before you start the truck. It still won't be warm when you jump in but it will get warm a whole lot quicker.
Sent from my SM-G900V using Tapatalk
C
Chucky33
Cummins 6.7
Ok the block heater let's it warm up quicker but it still doesn't get the defrost working quick enough. Even when I use the remote start and let it run for about 10 or 15 minutes it is still blowing cold air until I drive it for a couple miles
sbarron
Wasilla, Alaska
Welcome to the world of Cummins. To be fair, all the big heavy diesels are like that. Just a lot of mass to get warm, usually with big radiators. You could try to put a bra over your grill, (or cardboard as we'd use here in Alaska)
Power247
High Point, NC
6.4 HEMI
This is so true. I let mine idle long enough to scrape the frost off the windshield. Then just drive to burn off the rest. Even with high idle set you can burn a lot of time and fuel trying to get the cab warm.
Greg
crazzywolfie
under the truck
another vote for remote start:crazy:. i got one for my ramcharger and now wish i had bought one sooner. it saves me at least 5 minutes a day any day i got to work especially in the winter when it is freezing cold and your vehicle probably has to run at least 10 minutes to keep the windshield defrosted.
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
We sell a beautiful and small diesel fired heater that gets turned on by a timer. Fits under a seat. I'll try to remember the name of it tomorrow at work. It's maybe a Webasto.
strmtrooper
Evansville, IN
I agree with the winter cover, it should help it warm up quicker when remote started. One of the reasons I wasnt fond of my old trucks.
