With '19 and newer trucks the RF hub does not need to be reset for tire related stuff. I changed the TPMS thresholds and tire size with Alfaobd in my '19.I was not able to get the alpha to work correctly with my 2019, it can run its tests etc. but it won’t reset the RF hub. I use a Tazer for the tire size and it works great.
The first couple of time I would get an error when I entered the pin but the change would still work. The last adjustment I didn't even enter the pin and it still worked.
Eta: I also used the security module bypass from Kaodtech.
Tazer Ram works perfect for me and unlocks other features if needed.
I got lucky and the AEV Procal works perfect on my '19 PW. I actually bought it before they updated their info saying that it wouldn't work with PW's. You'll want something that also allows you to disable/modify the TPMS settings as you'll most likely be running lower pressures than what the factory system will allow you to run without the light/sounds coming on every time you start the truck.
Didn't your truck come with 285? Mine did.
I thought that was the starting size from Ram?
