kenpilot
- May 8, 2011
- 2
- 0
- 2008
- 6.7 Cummins Turbo Diesel
Hey guys, new to the forum and thinking about pulling the trigger on a 2008 Dodge Ram Mega Cab w/ 6.7 Cummins Turbo Diesel. Only problem is, it doesn't have an off road package and thus it has the small stock 17" tires on it and doesn't have the ground clearance that I would need for traveling in the woods on some pretty bumpy and nasty dirt roads. So my question is, would it be better to just put bigger tires on it or putting a 4" lift kit on it? I'm thinking if I just do the lift kit, it'll look pretty *** sitting up higher with the small tires on it. If you recoomend just putting bigger tires on it, what size would you recommend where rubbing wouldnt be an issue? Thanks in advance!!
