Biggest tire on stock 20s stock height
Stlram81
Sorry to ask a question that I know has been asked a million times. Tried search but no luck.
Looking ar getting tires. Want to go bigger but no lift. What's the biggest I could go on a stock 2011 sport.
Thanks
AustinB
Banned
San Diego, Left Coast
Does look a little stuffed up front though, I would get a level with bigger tires than stock. Will work either way.
S
Stlram81
So sounds like I at least need 2 level in front. Will 33/12.5 fit the stock rims? Or are they two narrow? (The rims)
Csanders1992
You'll be fine. Technically it's not recommended but tons of people have done it, some have even used wider and been fine. Just adjust tire pressure so they wear even
xrsman
Ontario
3.0 Ecodiesel
I'm running 35's on stock wheels, no issues. I also have 1.5" wheel adaptors to help clear the suspension components.
Sent from my SM-G920W8 using Tapatalk
REDE2GO
I was also wondering the same thing. I'm torn between 2 tires the BF Goodrich K02, or the **** Cepeck but the ***** come in 275 65 20. When I called tirerack customer support could not confirm if those tires would fit on the stock rim or cause any rubbing. I'm also trying to stay stock for now also.
Csanders1992
I believe the 275/65 will fit stock suspension. It'll definitely clear the suspension and fit the wheel great.
AustinB
Banned
275/65 is the best size with no lift or spacers. Try looking at tirebuyer for better pricing. They have ko2 in that size.
tdramman
Georgia
2015 Ram 1500 Laramie 4X4
I have 275/60 but was thinking of going with a 295/65 but I also have a 2 inch level in kit in the front.
Numnutz
Upstate New York
I would stay away from 12½" tires unless you change your UCA's
I'm running 285x65x20 which are 11.6" wide. I can just fit my fingers between the upper control arm and the tire. Anything wider than 285x65x20 on stock wheels will rub with out a spacer. I also have Bil's set at 2.1"
Csanders1992
Whether or not rubbing occurs with 12.5s is hit or miss. Some people are fine and some are not
Orca
