biggest tires on a stock rim
timber dealer
florida
2014 power wagon
Just got my 2021, will a .305 goodyear wrangler fit on stock rims withought any rubbing or other issues?
SeppW
Northern VA
Hemi 6.4L
Not so much height as width. With no level or lift kit, I'd say 35's, some are running 37 on stock suspension with little to no rubbing and possibly trimming. Which 305 are you referring to? I only see a 305 for 20in wheel and it's only 33.5 in height. About the same as the OE tire, but an inch wider.
T
timber dealer
florida
2014 power wagon
thanks for the input guys
what make are those tires phil frost?
Astewartconst
Illinois
I run Duratrac 35x12.5 on 2021 stock bead lock wheels. Once it was all said and done I measured them and the tires mounted on the truck are only 33.5” I felt a bit let down and sometimes maybe I wish I got a 37 (that probably measures at 35.5”) but it would certainly not fit in the spare
SeppW
Northern VA
Hemi 6.4L
Very few, if any, tires run true to size and since people adjust the tire under the PSI specified on the door jam placard for driving conditions or ride comfort, they'll be smaller in diameter. I think Interco does, but they are aggressive off road tires. Interesting write-up on tire diameter: https://www.intercotire.com/basics_tire_measurement
Chap
Northern NY
2019 Powerwagon
hemi 6.4
That white power wagon with the 37's looks bad ass. Makes me want to get 37's for my truck. I am running 35-12.5-17 Yokohama Geolander MT's, no rubbing at all. I have a 1.5 inch leveling kit, wonder if that with the 37's, there woud be no rubbing issues??
olyelr
Kewadin MI
You are basically at the same height as that white truck. Pretty sure he has thuren springs up front, which are 1.5” taller than factory springs. If you stick with stock wheels you would have very minimal rub on the fender probably, and some minor rubbing on the radius arm.
