RoadKing
Just want to make certain. If i do not change tires and install Bils at 2.1 the wheel well will raise 2.1" ?
My left front wheel well height is 36.75, rear is 39.625 which means the front will still be .77" lower than the rear if the Bils set to 2.1 is the lift you get.
Clearly I missed a bit of critical info of this mod. I some how got the impression that 2.1 leveled the front with the back but apparently the front will still be .75 to 1" in lower than the rear. Not level
Seems the 2.8 setting would be the level setting assuming 2.8" = 2.8" of lift is what you get. But I am not sure. I have read a lot of guys put .5" spacer on the rear when the front is set to 2.8"
I feel like telling the installer to set the Bils to 2.8" but from what I gather at 2.8" you need to get new UCAs?
Thanks
Thanks
