Beagler
First of all thank you to the folks on the board sharing all your info to help me with my decision and direction with my truck. Not much info on here for the folks wanting to do the 1.4 setting so I want to share what I did with my truck setup. First off I bought a 2017 Laramie 4x4 December 2017 and got a nice deal on it. I decided on the Bilstein leveling shocks set at 1.4 because I like a little rake and I tow quite a bit. I also didn't want to change the headlight setting and just leave them as is. I chose the Nitto Ridge Grapplers 285/60/20 for my new shoes since I do quite a bit of hunting and off roading. I wanted to stay as close to the original tire size to keep my mileage and speed in tune. After checking it with a GPS nothing changed. I can say after it's all said and done I did lose 1-1.5 mpg with my setup. I was getting 20.5mpg on long trips and 17.5 city/hwy. I'm assuming the weight of the tires was the cause for that but as they wear down it will get back to the original. The only thing I have negative to say about my setup is the quality of ride is not as smooth as the original. Using stiffer shocks and having to add more air to 10 ply tires does make a difference. When I was younger it didn't matter as much but as I get older I like the comfort. First pic is when I bought the truck. 2nd pic is after the install. Added a couple pics for those that haul things with their truck so they can see how the truck sits with the 1.4 setting. Thanks again for this forum!
