Bilstein at 2.8
Scgirardi
Any one have their Bilsteins at 2.8 and not need to do the rear coil spacer? So I have 39.5 rear stock and 36"front stock obviously 2.8 would even have me level. Any one else come across this? From what I've read 2.8 with either a 3/4 or 1" spacer will get you level.
jgruberman
EcoDiesel 3.0L
I have 2.8 in the front with a 1" spacer in the back. I did the spacer because I BARELY wanted to keep factory rake. When towing or carrying heavy loads, the back sags below the front but not by much. I'll look for a pic if you'd like.
jgruberman
EcoDiesel 3.0L
S
Scgirardi
Yea that looks good. Do you remember your stock measurements?
S
Scgirardi
Haha damn. I'm like 36" in front and 39.9" in back stock trying to see if that's normal or not....
jgruberman
EcoDiesel 3.0L
That sounds about right. I can tell you now that from ground to bottom of center of wheel well I am 39" front and 40.5" rear. Also, I'm running 285/65R20 if that helps you at all.
jgruberman
EcoDiesel 3.0L
Seems right since I did 2.8 in the front and 1 in the rear.
S
Scgirardi
Yea that's the height I'm shooting for. And 285 65 20 is what I'd like to run but they are so much more then the 275's....
joshhhh
