bilsteins and body lift?
kclineman
Hey just traded my 2011 laramie qc for a 2010 crew cab. I had the 5100's on my last truck and loved them. I just wanted more. I have a set of 5100's and a 3/4" rear spacer ready to go on. I want to run a body lift on this one. Ive been eyeballing both the pa 3" and the zone 1.5". I would really like to run the 3" but i'm hesitant with having to extend the steering shaft. Would love some feedback from anyone whis installed or running a similar setup. Pictures are always appreciated too. Cant get enough of seeing these trucks lifted up. Thanks.
MWeir91
Newfoundland, Canada
I'm running that exact set up. 3" PA body lift and Bilsteins set to 2.8". I love it, and the steering column extension, although it's a bit of a pain in the ass, wasn't too, too bad.
K
kclineman
Mweir91 i really like how your truck turned out. Not sure if you did the install or not but if you did any tips or tricks that might help me out when i do mine? Also how do the gaps look. I have the factory fender liners not sure if that will cover the gaps or not.
WhiteExpress
Midland, TX
That's a really nice height.
I've been contemplating a coil space (2wd) and a 3" BL to give me the big tough look.
Yo Nadz
St. Louis, MO
Hemi 5.7 Sport Crew Cab 4x4
Got the 3" BL and Bilsteins on mine. Love it. You'll need gap guards up front. Looks hideous without them.
K
kclineman
yonadz your truck looks sweet. thats exactly what im going for with a few twists. thanks for the post man. might have to pick your brain when i go to install.
K
kclineman
did you run gap gaurds glocknram?
that white kid
I ran the gap guards in the front to keep the water from splashing my headers and i have the 3 in pa system its not hard to put on just follow the instructions I mean I put mine on when I was 15 by myself in the garage
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Naw..I opted not to..could have, but it really doesn't bother me much at all. The back is fine, but the front could use them.
K
kclineman
hey yonadz do you have any rubbing issues going on with that wheel and tire combo?
MWeir91
Yeah i did the install myself, it wasn't too bad. The trickiest part is the steering column extension, but there's a little cylinder under your dash that moves back and forth a little that can give you just enough play to get it in if you need it. The liners cover the back just fine, and i ordered the gap guards for the front but haven't put them in yet. I'm not sure if i'm going to or not, I don't hate it with out them! Just PM me if you need any pointers if you do the install yourself!
K
kclineman
thanks mwier91. yah ill probably take you up on that when i get all my parts in. anybody know whos got the best price on the pa 3" body lifts?
Yo Nadz
St. Louis, MO
No rubbing before I installed the fender flares.
With the flares I get a little rub when turning left and hitting a big bump, such are pulling in a driveway, or half lock to the left in reverse. The rub is so minor that I'll live with it.
MWeir91
Best kind! I just bought mine from a distributor through eBay. Shouldn't be too hard to find on there. Everything you need comes together in a kit.
JBatSea
