Bilsteins are on!!!
Bertulis43
Delaware
Tires and bilstein 5100's were put on today along with alignment. It's dark out now to take pictures. The bils are set at 2.1, felt great to drive. No issues on the way home and on the highway. Felt a little slower lol. I will take better pictures tomorrow in the day light. But here are some teaser shots even though you all know what they look like @ 2.1
PassivAggressor
Looks good but good lord those wheels are curbed to hell! Unless it was the tire shop then bring that back and ask for new wheels.
Mineralram
Did you do the uca's also
Sent from my SM-G900W8 using Tapatalk
Mineralram
What year is your ram
Mineralram
Watch those uca's like a hawk, the bilsteins will start pushing up on the balljoints and they can pop out. 2014-2015 rams are bad for.
this and most people have installed new mevotech uca's to prevent early ball joint failure, in ky area i cannot find a shop that will do my truck without replacement due to safety factor
Mineralram
this and most people have installed new mevotech uca's to prevent early ball joint failure, in my area i cannot find a shop that will do my truck without replacement due to safety factor
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Not trying to steal the thunder from your thread, but should I replace my UCA's when I install my 6" suspension + Bil's this Spring on my 2012??
Adam
Bertulis43
Bertulis43
Delaware
Where can I look to keep a hawk eye on them so I can see if I have to replace them. I'm new to this stuff
Mineralram
Check upper ball joint
Bertulis43
Bertulis43
Delaware
It's bad idk what I'm looking at lol. You know anyone on here that ran into problems
Forcepro
I've been running my rancho quick lift (2" level) for about 20k miles now and my upper ball joints are fine on my 2014. It'***** or miss and seems to be more prevalent with guys that run the Bilstens at 2.8"
Forcepro
See attachment
This is the ball joint he is talking about. Look at it from the top, it should be flush with the top of the upper control arm.
Bertulis43
Bertulis43
Delaware
I'll keep an eye on it. I'll check it later n see how it is. Thanks guys. More pics to come
Also my tire pressure light is on. Picked it up last night n it was fine. Started it this morning 21 dg n 3 tires showed 30 they were all at 35. What should they be ran at
jvoid4
Houston
looks good!
Did your rims come from the factory black?
fordtech90
Jonesboro, La 71251
It's not the bottom side you need to check on it's the top side of the top ball joint. You should be able to hang a finger nail all the way around it and that's it. The added angle stress to the top joint is making it pop out and usually the inside will be lifted out of the control arm.
