BLOWER MOTOR RELAY - 2013 RAM 1500 5.7L
Dac717
Saskatchewan
Hi All,
My truck has intermittent power to the blower motor. I replaced the blower motor and resistor, checked power from the switch, and checked the ignition. Everything is good but still intermittent power. The problem I found out later was actually just the Blower Motor Relay. When the blower was not working, I wiggled and pushed the relay and the blower turned on. I have put in a new relay, tried constant pressure, and cleaned vigorously with electrical cleaner. I also tried tightening the connection on the female end with some tin foil. Unfortunately, the problem persists.
If anyone has some advice here I would greatly appreciate it. The only logical next step I can conclude is to buy a new fuse box (where the relay resides).
Thanks,
Devin C.
csuder99
Ram calls the fuse box "Totally Integrated Power Module" (TIPM) and it's not just a simple fuse box. That makes it somewhat expensive so before going that route have a look at all the connectors going into it, and if you feel comfortable open up the TIPM (plenty of videos on youtube). I think your area uses road salt so there is possibility of "green crusties" developing somewhere.
You can also splice in an external relay if that is within your capabilities. It's frequently done with TIPMs where one of the internal relays has failed.
jelih
HTX
Fought this issue last summer. Replaced fuse, relay and blower motor. It was towards the end of summer and that seemed to fix it. Then this morning I get in my truck to go home and no air blowing. Rage.
The first damn Google search result was this video from 3 years ago: https://youtu.be/Yoz78FKnVZE
I don't know why I couldn't find it last year, but I went outside to check before going to work and this is exactly my problem. Tightened up the connector with a pick and drove to work with AC.
Here is what mine looks like right now. I have time at work tonight so I'm going to search for part numbers and order a new whatever that green thing is called.
I'm also going to post this YouTube link on a few other blower motor threads because when I was having the problem last year I didn't see anyone else post it.
Dave0110
Wimberley,TX
Thanks for posting. Just fixed same issue
JmGuTe
PA
Like others said its a money making scheme by the manufacture. I just bought my truck and the seller said the wipers weren't working and it was the motor. Me being one to not fire the parts cannon at things did my reseach and drilled it down to the TIPM as well. Cause whats better charging 400 dollars for something or 5 bucks. Ya'll know the answer the manufacture is going to go with.
Stp2001
Tx
2013 longhorn 1500
Thank you for posting this. i had the same problem. now i am good to go! i almost bought a new blower motor.
DeputyChef22
Arkansas
I’m having this same issue on my 2015 Ram 1500. Can someone walk me through how to wire the external relay and fuse? I know a little bit of wiring but treat me like a newb please lol
Arturo Rojas
