Blower motor won't work on second speed
CapeRR
Nova Scotia
i haven't had a chance to look into yet but is it possible to be the resistor if 1, 3 and full speed work and not 2? Thinking it also may be the switch.
Anyone have an issue like this before and what was it?
Elevated 2013
Huntley, IL
In all my years of experience as a mechanic, 90% of the time it was the resistor block. The switch doesn’t generally go bad, but it does happen. I’d replace the resistor block.
OberonZed
Bucks County Pa
I just picked up my '13 outdoorsman and noticed my 2nd position on fan does not work either. You are not alone if you find a fix please post it @CapeRR
Rick R
Evans City, Pennsylvania
I've had it happen and it's a resister block. It's an easy fix to replace it. Its NOT the switch. Find a tutorial on U Tube to show you how to do it..
tap4154
California
3.6 V6
Great thanks. Def would be an easier fix.
I know my old Ford and other cars it was always a resistor block. Could you post a picture of where it is if you find it? Usually it's somewhere in the ducting which helps cool it down.
apriliaalex
NH
Replaced the resistor and mine still doesn’t work.
