Bora 1.5" do they stud trimming?
workd4it
I am running stock black oem rims on my 16 express qc. Want a better stance without trimming studs. So what is the magic number.1.50-1.75-2"? thanks for any input.
DavidN
Central Florida
Easy to find out - unbolt wheel, turn it so that the studs slip in the cavities of the wheel inbetween the mounting holes and use a caliper to measure the space between hub and wheel. Usually the rear studs are slightly longer than the front ones. (In my case 3mm/ ~1/8 Inch).
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
All my research is 1.75 and 2" and you won't need to sheer the studs. I confirmed this with Bora last week who is making my 2" now and tailoring the hub bore of 160.
BogsRam14
NJ
Had bora 1.5 on factory sport 20x9 rims no trimming needed. May need to trim on smaller factory 20x8's.
W
workd4it
yay I have the 8s in black so sounds like 2" is safe bet
charonblk07
Calgary, Ab
F1-A forged 349ci
It depends on what wheels you use if trimming is required on 1.5". Factory wheels should have reliefs cuts into them between the mounting holes which allow clearance of the stud. 1.75+" clears on all types of wheels.
Loganville GA
1.5 spacers with stock wheel= yes
1.5 spacers with aftermarket=No, pending if they have reliefs cuts into them.
See picture for reference
W
workd4it
ok guys measured a stud today when rotating tires. 1 9/16" and I have the pockets in the back of my rim roughly.25 deep so I am thinking 1.5 boras will work. Do you guys agree? thanks
DavidN
Central Florida
If you measured correctly and do the math - 1.5 spacers will fit just fine with your rims.
Stud length (1.5625) minus pocket depth (0.25) is 1.3125.
