Borla Muffler Install with pics
markusaf81
I saw RysRams post about 2 months ago about the Borla install and so I jumped on the bandwagon. Got the muffler from Nick and ordered all the clamps and extension pipe per RysRam and it’s been sitting in my garage for over a month.
Install was pretty easy, I think I’m gonna take it back off again and shorten the extension pipe up a bit. I think my tips are sticking out a little too far. If anyone wants to measure I’d appreciate it.
So I bought a Borla Muffler part 400486 (bolt on), an 18 inch long extension pipe, two 2.25 clamps, one 3 inch clamp, and a 3 inch SS clamp. Old muffler came off alright. Sprayed PB on all the clamp bolts, bolted everything up, and now I’m gonna go for a spin.
Here are the pic of it installed.
Remember, if anyone wants to measure their tips like I did and let me know the dinension, I’d appreciate it.
f07fb1b7a424eedad6531fc9c91513ae.jpg3cee74ea5d12c5fad88ffb1688cb1824.jpg0dedfde5ed3b355fcc571417b538a9ea.jpg
markusaf81
markusaf81
markusaf81
markusaf81
VB712
Maxi_built
Va Beach
Just cut 1” off the extension pipe. That will place your tips back where they should be.
markusaf81
markusaf81
Yeah, I just searched through the forums and looks like tips are usually flush. What sucks is that everything has to come off to cut the pipe...muffler, tail pipes, and all that. Oh well, lol.
markusaf81
markusaf81
Looks good. My tips are flush with the rear bumper.
Yeah, I needed my ext pipe to be 16 inches.
My old muffler had slots in the two outlets and the 2 tail pipes had a small metal tab on top, almost like it was to lock them in. So either I grind the tab down or take the ext pipe back off and cut to 16 to get that inch. I’ll probably go that route, it’ll drive me nuts
RysRam
Ontario, Canada
Yeah, I mentioned the alignment pins in my original thread. They need to be ground off to get enough of the tailpipe into the muffler outlets. The mid-pipe has an alignment pin too....it's right where the the 3" band clamp connects the extension pipe to the mid-pipe.
jmh288
Chicago
2018 (2017 1500 KIA OCT 2017)
Which exhaust hangers did you guys use to hold the muffler and tail pipes in place? The Borla I looked at didn’t have any.
Sent from my iX using my iThumbs via Tapatalk
markusaf81
markusaf81
I didn't use any...there is a hanger right before the extension part starts and then there are 3 that hold the tailpipes up.
Now there are 2 not being used, there was one at the front and the back of the muffler. Reading a lot of the forums, I haven't seen anyone that added them back in. As of now, its ridiculously sturdy, I get no movement.
I was slightly concerned for down the road, but I don't think it will be an issue. If there is a bolt on hanger option I might look into that. The new setup weighs about 40 pounds less then stock.
jmh288
Chicago
Being a lot lighter is good. Hopefully it’s sturdy enough. If not there are a few different types of hangers available.
It’s a long stretch with less support. That was my only concern.
markusaf81
markusaf81
I agree, ill look to see if my local store has one of the universal hangers and I might throw one or 2 of those on
gdawg55
GA
Nice pics of the install. How do you like the sound? I have the same muffler and really like it. I don't have any additional hangers either and it's solid as a rock.
RysRam
Ontario, Canada
Did your truck have a ground strap attached to the muffler? My truck did and I broke it when removing the OE muffler. I forgot all about it.
markusaf81
markusaf81
I like the sound, was looking for a slightly deeper tone without it being annoying and I think I like it. Decently quiet unless you romp on it...plus I just shaved 50 pounds off my truck, lol.
markusaf81
markusaf81
Sure did, let me know if your truck blows up, if so ill ground mine since I'm a few months behind...lol
La ratilla
