The man upstairs was looking out for him for sure!I was at my friends house a few years ago and he was working on his Chevy. His truck was a 3/4 ton with a welder in the back and he had a air bumper jack attached to his rear bumper. He had it high enough so he could sit under his truck and do whatever he was doing. He got out from under his truck to get a part and right after he got out his bumper ripped off and the truck slammed to the ground. No jackstands. he was very lucky.
I use ramps and jack stands under each front wheel along the chocks under the rear wheels and make sure the emergency brake is on ... I also have air suspension and raise the truck to its highest point which gives me that much more room ..Just curious if anyone is using strictly bottle jacks and jack stands when raising the truck for DIY oil changes vice using ramps or a trolley jack? If so, what are you using as the jack points for the bottle jacks on the truck? Thanks
Mike
I tried that once but found that the combination of the raised suspension and ramps put the truck at an awkward height for doing an oil change. A little too high for laying on my back and not high enough to sit up. To each his own I guess.I use ramps and jack stands under each front wheel along the chocks under the rear wheels and make sure the emergency brake is on ... I also have air suspension and raise the truck to its highest point which gives me that much more room ..
I put a Stahlbus drain valve on my oil pan so it's just a matter of unscrewing the cap, insert the drain line valve, turn, and voila oil is draining ... Makes it easy, and no tools to play with under the truck ... I also use a creeper to slide under ...I tried that once but found that the combination of the raised suspension and ramps put the truck at an awkward height for doing an oil change. A little too high for laying on my back and not high enough to sit up. To each his own I guess.
