So, do you wear both suspenders and a belt too?Ramps with jack stands. I never just use ramps. I also chock the rear tires once up on the ramps.
Absolutely and a pocket protectorSo, do you wear both suspenders and a belt too?
Yes, they slide and it's a pain in the butt. However, if you can get up on them without them sliding they are the way to go.I was always curious about using the ramps.
If you use them on a garage floor; do they slide at all when you drive up them?
Metal ramps on cement, in my experience almost always slide
I have a set of heavy duty metal ramps, they have nothing mounted on them that have a gripping surface.
They just take up room on the garage floor.
I just use my composite plastic ramps, but they are just a bit too steep to use with my Sport Bumper
So i have some 2 X 6s, cut to use as an approach ramp
That is why I made HD wood ones, though I did have heavy steel ones, but the bumper would some times hit. I have some rubber sidewalk tiles, about 16 in sq made from recycled tires that work great under stull like this, I use them under my grinder stands as well Keeps stuff from sliding around, or you could make a wood base with rubber pads, mine had rubber feet, but over the yrs they wore out. BTW the ones I made out of brigde planks where about 5 ft long, but I had a 40x 80 ft shed, so had room, and a FEL.Metal ramps on cement, in my experience almost always slide
The Rhino ramps work great in gravel too. I had my RAM (in 4LO) and I have a Ranger (RWD), and a VW and Mini (FWD). The ramps work great for all of them in the gravel or on the pavement of my driveway.My garage floor is polished concrete. Metal ramps slide badly on it. I picked up a set of Rhino Ramps and no more sliding. They are a heavy duty plastic, and have rubber inserts built into it. They might actually slide on my floor if it was wet (very slick floor when wet) but I haven't had any issues so far. If there is any texture at all on the surface you won't get any sliding from Rhino Ramps.Can't speak to how well they work on gravel though. Plus they don't have a steep of a ramp as some of the steel ramps I've owned, and the front air dams don't touch them. I can even use them on my Audi without the body work touching them.
