Bought new tow mirrors For my 2014 1500 but have install question
nadesico25
Graham, NC
When they are rotated up do they adjust properly or are they backwards
B
big_red06
2014 Bighorn
I will try it and let you know haven't tried to adjust them in the flipped up position
B
big_red06
2014 Bighorn
so i tried the mirrors up in the tow position today the adjustments are opposite of when they are down takes a little while to figure out but once positioned properly they afford an excellent field of view in my opinion hope this helps
Airborne63
You have to get you truck reflashed with the sales code for tow mirrors to have them adjust right when flipped up.
nadesico25
Graham, NC
Airborne 63 is correct take it back to them and tell them they forgot to flash the "LEG" sales code. that will fix your problem and allow them to adjust properly when they are in the rotated up position
gigabyte3
Do you by chance have the part number(s)for the mirrors? Looking to put them on my 14 as well. Thanks!
B
big_red06
2014 Bighorn
Will take a look in the morning and see if I can get the part numbers off them for you I bought them used from somebody with the same year truck as mine that he traded so I just went with that and took a chance on them. I'm glad I did though because I really like them the only advice I can give you is check with your local dealership let them run your vin and see if you have the correct modules inside the door for them to work my truck came with no signal or puddle lights from the factory on my regular mirrors but when my dealer ran my vin they were able to verify my truck would be capable of utilizing them after the proper code was added so now I have those options as well
gigabyte3
I found some at moparpartsonline.com. Their part number is: 82214909AB.
The description says they fit 2013-2016 trucks. Does this sound right?
gigabyte3
Double checked with the dealer today. Going to order a set. Sounds like if you have the power and heat already, the tow mirrors, for at least the 14's, will work, just need the sales codes added for the lights
TMFMK
