? Bout dash bezel round stereo....
4.7 v8
could you guys show or explain how to remove this bezel since it needs to be replaced in order to install the full center console?
Inside Man
N.E. Ohio
Quick search in the search column will lead you in the right direction.
There is a pocket with a liner in it on the very top of that piece. Take the liner out and you'll find two torx bit screws. Remove those. Open lower cup holder, then grab the center bezel and pull straight out. Other than the two torx screws, it's only held on with clips from the back of the bezel piece. Good luck
jacobsjl88
When you remove the screws, I found it easy to use a small screwdriver and a rag or paper towel to snap those clips out. The rag or towel behind the screwdriver will help lessen the damage to the surrounding dash. Once they are out, just pull and off it comes
Inside Man
N.E. Ohio
Yea, it's not like the old style clips. These things take a little ass to remove them. I just gave it a good yank and it came right off. Same with the overhead console. No screws in that though.
