Box building 101 why buy fox just build a box!
Bkhsvt
Chicago IL
Just some pics of some recent box build action.
Bkhsvt
Bkhsvt
Chicago IL
Started with the mold of the underseat trimmed up and added layers for strength
Bkhsvt
Bkhsvt
Chicago IL
Made the bottom part of the box, this will be attached to the fiberglass tub. It is the same size as the fold flat floor to match the theme of the truck and the other side
Bkhsvt
Bkhsvt
Chicago IL
Made the opening for the tub for attachment.
Bkhsvt
Bkhsvt
Chicago IL
Started attaching the tub to the box frame.
Bkhsvt
Bkhsvt
Chicago IL
Measured the interior volume with water and kept the side open cut to the right size as the interior volume needed for specific sub and capped at correct size. Glassed and bondo in place, shwing!
Bkhsvt
Bkhsvt
Chicago IL
Chopped and routed up the top piece to go on the bottom tub/frame assembly started planning on sub placement
Bkhsvt
Bkhsvt
Chicago IL
Made some openings for the sub and amp tray/ kept the tray large for future amp size change possibilities. There is a trim ring going over anyways. Later on in the build I ended up changing this to be exact for the pdx
Bkhsvt
Bkhsvt
Chicago IL
Few changes with trim rings, and some terrible picture angle
Bkhsvt
Bkhsvt
Chicago IL
Lil closer but still bad pic. I'm modding holes in this for led to shine through from amp
Bkhsvt
Bkhsvt
Chicago IL
Last one for now. Gotta do a couple other mods but it will be off for line x
Soon.
I am debating on Polk MM 6.5 comps and 6x9s to keep this simple. Maybe running a kicker front row to tie in signal from the head unit. When ever I get around to doing the actual wiring.
fun stuff! I'll keep yall in the loop
quietpeen
2021 TRX
Hellcat
Looking real good
UNBROKEN
2012 Ram R/T
It would look great with a little bondo work to blend the trim ring into the rest of it.
Bkhsvt
Bkhsvt
Chicago IL
I'm debating the bondo and smoothing....I may not to keep them removable. Haven't decided on that part yet. Thanks for the replies!
I'm planning on making a few more for some people so they have custom tailored boxes for their subs and amps. My next goal is to get molds for chevy and ford so I can make prefab boxes there to.
This box should fit any ram roughly 02 and up.
Bkhsvt
Bkhsvt
Chicago IL
I decided no no thank you on line x and went with carpet...
Bettula
