Brake bleeder
Several members on this forum use this brake bleeder: Motive Products 0103 Power Bleeder Fits Late Model Chrysler Vehicles https://a.co/d/8E4lJiD
Shawn Burns
Army Law Enforcement
Lewisburg, PA
2016 Rebel
I use the motive one as well. I've tried an Amazon version of the HF one that you listed. I never could get it to work well without pulling air through the screw. Let us know how it works out. The reviews on HF seem good
Different Drummer
North East
Pentastar V6
I just gravity bled mine. Didn't even have to jack up the truck or remove a tire.
Fluid ran quickly and no worries about air in the lines.
Maybe I am missing something but it sure was easy.
1 MEAN66
Waterford NY
Hemi 5.7 VVT-MDS
Ya that one is made by "Motive Power" amazon $79 Wally world $59. As a tech I also got their universal adapter kit. As it made the unit work on anything. Have had mine for 25 plus years. It is also "air operated" difference is no compressor needed. the handle is the "bicycle" pump to but the fluid under pressure. Amazon (I have found) is almost never cheaper (less expensive) and if it (whatever you order) comes damager or missing parts. The "RETURN NIGHTMARE" begins.
PS a nice place to get QUALITY TOOLS - tooltopia.com
Let your fingers do the shopping online for the best price.
Have never had a problem returning anything to Amazon, even things that weren't even what was ordered. I've only had to call customer support once, any other returns were done online and the item was dropped off at the local UPS office (don't even have to package the item to be shipped)
Jeepwalker
WI
2012 Reg Cab, 4x4
For occasional use, the unit the brake bleeder the OP is considering is perfect.
If a guy has many vehicles, does a lot of mechanical work, or plans to bleed brakes more frequently, the unit in the link below may be worth investing more money on (for easier use, greater flexibility). I have used a similar unit many times (like the dealers use), and having a suction AND feed hose and being 12V is really nice. You can take it from vehicle to vehicle using vehicle battery power. It's not for the one-off brake bleeding operations, but great for a well-equipped tool shop.
Jeepwalker
WI
2012 Reg Cab, 4x4
Quite frequently I just use the suction side of a pressure bleeding machine to bleed the brakes (sucking through the bleeder screw). I'm talking about a motorized vacuum side of a pressure bleeding machine. The secret is to apply a drop of 90W gear oil to the threads of the bleeder screw after you open it up. The vacuum sucks some lube into the threads which seals the threads ...and in the process it lubes the threads up too.
Another benefit is it sucks the fluid out slower, easier to manage. A crafty guy could fab up a 12V mild suction machine from a simple small vacuum pump. Just thought I'd pass it along.
Note: Hand vacuum pumps are terrible.
gofishn
Iowa
hemi 5.7L, 345 cu in
That's the one I just bought. Saw it mentioned in another thread and thought I always wanted one.
Cars are '22 & '21 but they will need loving soon enough.
Besides, Boy could use it, for now.
gofishn
Iowa
Wow! I'd avoid your Amazon, at all costs.
Glad my Amazon is so easy to return for refund.
Simply drop off at local UPS store and refund is usually credited by the time I get home 10 minutes later.
Many things, mostly under $10 kind of stuff, they just say keep it and refund my money.
Might be how manys ales vs returns kind of thing, Not sure but am darn sure I like my Amazonian Gods.
I give them apittance and they grant me gifst beyond reckoning.
Walmart?
make sure its sold by walmart.
Buy off walmart.com, seems to me, like the item I actually get, came from some crackhead, selling stolen garbage, out of her Dilapidated squat housing , in condemned neighborhood. Return to store, get receipt, then got to wait, wait wait, for a refund and hope you actually get it, before you completely forget about teh thing.
Nope.
From now on. If I buy from Anywhere, I make sure its being sold and delivered by that store.
Pay more at amazon?
Again, I search and rarely find a better deal, from a source I trust.
Personally, being poor, I much prefer to spend my money, once, and buy a quality product, from a known source,
and not bother trying to get the lowest possible price, on 14 continents, spread across 4 planets, in 3 different Galaxy's
and end up with conterfiet or, like above example, some stolen junk, that's been beat to death.
I like my Boxes, nice crisp and new looking.
never been much fro scratch adn dent stuff, but, to each his own.
Sorry your Amazon sucks.
jejb
NW Arkansas
Trick there for pretty much any brake bleeding other than gravity is to pull the bleeder out of the caliper, wrap the threads in teflon tape and reinsert.
A_mod_too_far
Colorado
So I spent like a month researching systems last summer and came to the conclusion that speedi bleed is best value for quality and cost
I was impressed when I got mine how easy it was to use and how much air I had in the lines. The build quality is way better than the chinese stuff on amazon and harbor freight.
Midknight
New Jersey
I have the exact bleeder from HF and it works really well. On my Ram the reservoir opening doesn’t allow the clamp for the gravity feed bottle. That’s ok because you can prop it up without the clamp. Nice thing is this allows you to suck out the fluid in the reservoir and then switch over to connecting to the bleeders. Very fast and no mess setup.
DodgeDude99
Oak Lawn, Illinois
I had bought the HF bleeder when I swapped to Hellcat brakes on my ‘06 Charger. Didn’t work, not enough suction. Bought the Motive, had all 4 bled in 20 minutes.
MRFREEZE57
pacific northwest
After bleeding is a good idea to activate the ABS module. I did this by driving on a slick road and slam on the brakes then do one more flush. The easiest way would be to have an analyzer to connect that operates the module to get some fresh fluid thru the ABS.
