brake pressure??
MoparMagic'00
Arkansas
5.2 Magnum
So the other dday when i had to replace my power steering pump i moved the truck maybe 3 lengths And shut it off.. After i crawled over and begun disassembly i could hear air.. After a second of listening i reached over and loosened the reservior cap for brake fluid and it quit.. I do happen to have fluid residue on the outside of cap now and then but in the last 4 years only added maybe a few oz.. What could be the problem? Booster? Cap? I may add brake light and abs light are on and the proportioning valve has paint marked numbers like a yard does.. Dont know the story behind that.. 2 wheel abs disk front drum rear 2000 auto 5.2 auto... If that is relevent. Thanks
rowdyram
magnum 5.9
Are you sure the air stopping when you removed the cap wasn't a coincidence? Not a/c equalizing? If not its a possibility your brake booster or booster check vale is leaking.
jwheeler
Washington
^ my thoughts. Can you make it happen again? There is no reason the brake master cylinder reservoir would be pressurized.
MoparMagic'00
MoparMagic'00
Arkansas
5.2 Magnum
It was definatly the reservior.. Had my ear less than a foot from it..
