Build Sheet Failure
ThePunisher
Harrowsmith
I've bought several Ram trucks, and have always been able to get a build sheet. It's a 2022 Ram 1500 Classic that i bought in July but have done very little with. I attempted to get a build sheet, but it keeps saying no vehicle found. Really, I just want to know what transmission is in the truck...it's a Hemi with an 8 speed and my window sticker says "8 Speed Torque Flite Transmission" but doesn't say which model. Anyone know why the build sheet is not working?
The 5th Gens with the 5.7 get the heavier duty 8HP75.Transmission pans/filters are the same as the 8HP70,if that's the reason behind your curiousity.
The last 2 digits of the 8 speeds are it's torque rating in Newton Meters X 10
ie:the 8HP70 is 700 NM or 516 lb-ft
the 8HP75 is 750 NM or roughly 563 lb-ft
Those are their constant torque ratings,they'll handle more then that for short periods of time
alpinegreenneon
Air Force
South East Wisconsin
I tried the build sheet link and had no trouble getting the correct build sheet for my 2018 Ram. Are you using all capital letters? Are you typing correctly?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
ZF 8 speed transmissions are in vehicles with different size engines
8HP70 is behind the HEMI engine & i believe the 3.0 eco-diesel
8HP45 is behind the 3.6L
8HP75 Heavy Duty Rams ...
Newer Light Duty Rams may use a stronger transmission
I have not been able to find what the Sales Codes for the 8HP70 transmissions mean
dfk vs dfd transmission
The HD trucks with the 8 speed use an upgraded version of the 8HP75 that's in the 5th Gen 1500's.
Smooth and reliable, the 8HP75-LCV offers a level of shift refinement not usually seen in Heavy Duty trucks: Fully electronic operation. Innovative and convenient rotary E-shifter. On-the-fly shift mapping with more than 40 individual maps to optimize shift quality/points regardless of load or conditions.Jan 14, 2021
If you don't mind, can you try my vin?
1C6RR7GT0NS192951
I missed the fact you have a 4th Gen Classic.
You have the 8HP70 8 speed.
It might be called a torque flight in your 22,but it's the ZF 8HP70 if you have the 5.7
T
ThePunisher
Harrowsmith
Yes, its a 5.7. Thank you for clearing that up. Did the build sheet work for you? I must have had some sort of moment, because I just tried it again, and it worked. Thank you for all the help though!
alpinegreenneon
Air Force
Nice truck!!!!!
Equipment Listing
VIN 1C6RR7GT0NS192951
Vehicle Description 2022 RAM 1500 SLT QUAD CAB
STANDARD EQUIPMENT
4X4
MONOTONE PAINT
160 AMP ALTERNATOR
730 AMP MAINTENANCE FREE BATTERY
ELECTRONIC STABILITY CONTROL
ANTI-LOCK 4-WHEEL DISC BRAKES
PREM VINYL DOOR TRIM W/MAP POCKET
FRONT HEIGHT ADJUST SHOULDER BELTS
SUPPLEMENTAL SIDE AIR BAGS
ADVANCED MULTISTAGE FRONT AIR BAGS
SUPPLEMENTAL FRT SEAT SIDE AIR BAGS
CARPET FLOOR COVERING
FRONT FLOOR MATS
REAR FLOOR MATS
DRIVER/PASSENGER ASSIST HANDLES
REAR UNDERSEAT COMPARTMENT STORAGE
ELEC SHIFT-ON-THE-FLY P/TIME T/CASE
215MM FRONT AXLE
3.21 REAR AXLE RATIO
235MM REAR AXLE
CONVENTIONAL DIFFERENTIAL FRT AXLE
TINTED GLASS WINDOWS
TINTED WINDSHIELD GLASS
REMOTE KEYLESS ENTRY WITH ALL-SECURE
SENTRY KEY THEFT DETERRENT SYSTEM
DASH LINER INSULATION
FLOOR TUNNEL INSULATION
INSTR. PANEL COLOR KEYED BEZEL
200 KPH PRIMARY SPEEDOMETER
TEMPERATURE & COMPASS GAUGE
VAR INTERMITTENT WINDSHIELD WIPERS
DUAL NOTE ELECTRIC HORNS
12V AUXILIARY POWER OUTLET
POWER ACCESSORY DELAY
N95+BIO HVAC CABIN FILTER
POWER LOCKS
PWR FRONT WINDOWS, 1-TOUCH,UP & DOWN
INSTRUMENT CLUSTER THEME 1 (BASE)
FRONT PASSENGER SEAT BELT ALERT
VEHICLE INFORMATION CENTER
TRAVELER/MINI TRIP COMPUTER
AUTOMATIC HEADLAMPS
CARGO AND CHMSL LAMP
FRONT LICENSE PLATE BRACKET
REAR WHEEL WELL LINERS
"CLASSIC" BADGE
FRONT BUMPER SIGHT SHIELDS
26 GALLON FUEL TANK
ENGINE BLOCK HEATER
SPEED CONTROL
DIAMOND BLACK CRYSTAL P/C
FIXED LONG MAST ANTENNA
SIRIUSXM SATELLITE RADIO
POWER RACK AND PINION STEERING
FRONT HEAVY DUTY SHOCK ABSORBERS
FRONT STABILIZER BAR
REAR STABILIZER BAR
TILT STEERING COLUMN
TIRE CARRIER WINCH
FULL SIZE TEMPORARY USE SPARE TIRE
17" STEEL SPARE WHEEL
PARKVIEW REAR BACK-UP CAMERA
NON ADJUSTABLE PEDALS
PICKUP BOX
R1234YF A/C REFRIGERANT
7 PIN WIRING HARNESS
TRAILER TOW W/4-PIN CONNECTOR WIRING
LOCKING TAILGATE
BODY COLOR FUEL FILLER DOOR
DOOR TRIM PANEL MODULE
GLASS MODULE
CENTER CONSOLE PARTS MODULE
SEAT PARTS MODULE
INSTRUMENT PANEL PARTS MODULE
DOOR PARTS MODULE
FRONT END PARTS MODULE
TIRE & WHEEL PARTS MODULE
BUILD TO CANADA MKT. SPECIFICATIONS
CANADA DEALER RETAIL
ZONE 21-CANADA-ONTARIO
DS/6322 VEHICLE FAMILY
FOUR WHEEL DRIVE (4WD)/(4X4)
2022 VEHICLE SPECIFICATIONS
PRICE CLASS H - SLT
6 FT. CARGO BOX
QUAD CAB
1500 SERIES
VEHICLE ORDER TRACKING
CANADA SPECIFICATIONS LABEL
ONTARIO PROVINCE CODE
CANADA COUNTRY CODE
OPTIONAL EQUIPMENT
PREMIUM CLOTH BUCKET SEATS
BLACK
TECHNOLOGY PACKAGE I
LUXURY GROUP
WARLOCK DECOR PACKAGE
ELECTRONICS GROUP
HEATED SEATS AND WHEEL GROUP
REMOTE START & SECURITY ALARM GROUP
UTILITY GROUP
WARLOCK
BUCKET SEATS
SUPP. SIDE CURTAIN FRT/RR AIR BAGS
HEATED FRONT SEATS
REAR 60/40 SPLIT FOLDING SEAT
FULL LENGTH UPGRADED FLOOR CONSOLE
FOLDING FLAT LOAD FLOOR STORAGE
OVERHEAD CONSOLE W/GARAGE DR OPENER
ROTARY SHIFTER-BLACK
ALL AUTOMATIC TRANSMISSIONS
8-SPD AUTO 8HP70 TRANS (BUY)
ANTI-SPIN DIFFERENTIAL REAR AXLE
5.7L V8 HEMI MDS VVT ENGINE
REAR WINDOW DEFROSTER
REAR POWER SLIDING WINDOW
SUN VISORS W/ILLUM VANITY MIRRORS
REAR VIEW AUTO DIM MIRROR
AUTO DIM EXTERIOR MIRROR
POWER HEATED MIRRORS, FOLD-AWAY
ALL VEHICLES W/POWER MIRRORS
POWER SUNROOF
2-DOOR PASSIVE ENTRY, FRT DOOR LOCKS
PUSHBUTTON START
AIR COND ATC W/DUAL ZONE CONTROL
CLUSTER 7.0" TFT COLOR DISPLAY
115V AUXILIARY POWER OUTLET
GPS NAVIGATION
GPS ANTENNA INPUT
POWER LUMBAR ADJUST
POWER 10-WAY DRIVER SEAT
SPORT TAILLAMPS
GLOVE BOX LAMP
EXT. MIRRORS W/SUPPLEMENTAL SIGNALS
EXTERIOR MIRRORS COURTESY LAMPS
POWER-FOLDING MIRRORS
BLACK EXTERIOR MIRRORS
REAR DOME W/ON/OFF SWITCH LAMP
BI-FUNCTION HALOGEN PROJECTOR H/LAMP
DAYTIME RUNNING HEADLAMPS, DEDICATED
FRONT LED FOG LAMPS
LED BED LIGHTING
SECURITY ALARM
BLACK POWDER COATED FRONT BUMPER
BLACK POWDER COATED REAR BUMPER
BLACK HEADLAMP FILLER PANEL
BLACK GRILLE W/RAM LETTERING
MOPAR SPORT PERFORMANCE HOOD
FRONT WHEEL WELL LINERS
BLACK WHEEL FLARES
BODY COLOR DOOR HANDLES
WARLOCK DECAL
DELETE BLACK-OUT TAPE
5.7L HEMI BADGE - FLAT BLACK
4X4 FLAT BLACK BADGE
BLACK EXTERIOR BADGING - TRUCKS
BLACK RAM HEAD TAILGATE BADGE
MOPAR SPORT PERFORMANCE HOOD DECAL
50 STATE EMISSIONS
DUAL EXHAUST WITH BLACK TIPS
HEAVY DUTY TRANSMISSION OIL COOLER
ENGINE OIL HEAT EXCHANGER
EXTERIOR MIRRORS W/HEATING ELEMENT
ELECTRONICALLY CONTROLLED THROTTLE
HEATED STEERING WHEEL
HEAVY DUTY ENGINE COOLING
NEXT GENERATION ENGINE CONTROLLER
ALL RADIO EQUIPPED VEHICLES
9 ALPINE SPEAKERS W/SUBWOOFER
STEERING WHEEL MOUNTED AUDIO CTRLS
HD RADIO
8.4" TOUCHSCREEN DISPLAY
APPLE CARPLAY
GOOGLE ANDROID AUTO
USB HOST FLIP
MEDIA HUB (2 USB, AUX)
SIRIUSXM GUARDIAN, 1-YR TRIAL
SIRIUSXM TRAVEL LINK
AUDIO JACK INPUT FOR MOBILE DEVICES
REMOTE USB PORT
SIRIUSXM TRAFFIC PLUS
4G LTE WI-FI HOT SPOT
ALL VP4 RADIOS
LEATHER WRAPPED STEERING WHEEL
REAR EXTRA HD SHOCK ABSORBERS
P275/60R20 BSW ALL SEASON TIRES
GOODYEAR BRAND TIRES
UCONNECT 4C NAV WITH 8.4" DISPLAY
ALL ALUMINUM WHEELS
SEMI-GLOSS BLACK HUB
20X9.0 SEMI-GLOSS BLACK ALUMINUM WHL
PARKSENSE REAR PARK ASSIST SYSTEM
REMOTE START SYSTEM
TIP START
TOW HOOKS
CLASS IV RECEIVER HITCH
UNIVERSAL GARAGE DOOR OPENER
TIRE PRESSURE MONITORING DISPLAY
TRAILER BRAKE CONTROL
ENGLISH/USA LANGUAGE
INTEGRATED VOICE COMMAND W/BLUETOOTH
WARLOCK INTERIOR ACCENTS
HUMIDITY SENSOR
ELECTRONIC SHIFT
RAISED RIDE HEIGHT
ENGINE CALIBRATION FLASH, V2
FOR MORE INFO, CALL 888-539-7474
SIRIUSXM RADIO SERVICE
4.5 ADDITIONAL GALLONS OF GAS
SPRING - LEFT FRONT
SPRING - LEFT REAR
SPRING - RIGHT FRONT
SPRING - RIGHT REAR
GVW RATING - 6900#
FAM: DS TRACKING: 10701T03 MY:2022
FAM: DS TRACKING: 11129T25 MY:2022
CUSTOMER PREFERRED PACKAGE 2TF
CUSTOMER PREFERRED PACKAGE 27F
SCHEDULE D TO C TRACKING
FEDERAL A/C EXCISE TAX
ONTARIO TIRE SURCHARGE
SALES TRACKING
SPECIAL SCHEDULING CONDITION III
4X4 TRACKING
WARREN TRUCK ASSEMBLY PLANT
EASY ORDER
ORDER CONVERSION TRACKING
SALES DISTRIBUTION TRACKING
CANADA REGION GROUP
NAFTA REGION
Boy they're getting cheap if the rear wheel liners are now an option.
Nice truck though.
