It's only for people making more hp or those with full bolt-ons that drive like idiots and do everything that will shorten the life of the trans.
If it hurts when you stick a fork in an electrical outlet, the doctor isn't going to redesign the outlet when you complain about it, he's going to tell you to not stick the fork in the outlet. He can put a plug in the outlet but that won't stop you from removing the plug and sticking the fork in it again, and again, and again.
If you want to keep blowing a trans every time you do the exact same thing, why wouldn't you just change the way you do it, it doesn't actually affect the way you drive at all. It's actually more fun as a driver to manually downshift 2 gears than to just step on the pedal, it's more interactive and something I've been doing for 3 years with an engine I guarantee makes more HP/TQ than yours does and I'm still on the same trans.
