Bullydog installed!
sausec17
Banned
ATLANTA
Installed my BD tuner today, took about 20min. Really wakes up the truck with these 37's. Just running the Regular 89 tune until my next fill up.
Few questions, where is a good access point in the firewall to run the wires?
Also, if I wanted to change the tire size or throttle boost again, I would have to re-install the tune?
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
There's a rubber boot on the drivers side that the main harness runs threw. That's where I ran mine.
Yes any time you change something there is a uninstall and re install. But it's not as bad as the full version.
When you change something it will ask if you want to install it now.
xrsman
Ontario
3.0 Ecodiesel
This is where I went though. I found it to be the easiest for my interior lighting and CB power cable!
Sent from my SM-G900W8 using Tapatalk
xrsman
Ontario
3.0 Ecodiesel
Sorry it sent the pics twice, I'm not sure why it's doing that!
jpf8653
I used the heated seats fuse. Look in the manual I forgot the number
sausec17
sausec17
Banned
ATLANTA
I got an express bro, no heated seats here lol
xrsman
Ontario
3.0 Ecodiesel
Check M23, that comes to mind when I think about what fuse I tapped! It turns on with the key and off with the key. Still liking the bully dog?!
sausec17
sausec17
Banned
ATLANTA
Roger that. I'll check that tomorrow. So far I have no complaints with the BD. The main thing I needed it for was to change tire size. Once I did that the tune was icing on the cake. Really let's the 37s spin now! Excited for the 93 tune next fill up!
apepe0738
Peoria, Arizona
2012 Ram 2500 Crew Cab 4x4
Any reason why you can't tap into the cigarette lighter? Mine shuts off with the key. Just curious for when I get mine, seems it would cut the install time...
xrsman
Ontario
3.0 Ecodiesel
I just checked where mine is tapped in. I used M6 which is for power outlet 1 ACC. I must have been thinking of my train horn when I said M23 because that's one of the horn fuses! Lol
sausec17
sausec17
Banned
ATLANTA
Awesome, thanks brother!
Raadz
