WilCon76
- Apr 30, 2013
- 74
- 10
- Location
- MD
- 2013 Express 2WD
- Hemi 5.7
So the BD unit offers a lot of things I don't really care about. Simply because my truck has the 7 inch in dash unit that does all of this already, to include gauges for trans temp, coolant temp, trailer gain if I get the module etc. My questions is for those that have installed this if you leave these alone and just load the tune do they impact the truck or are they not used? More clearly is I want the truck to use what I have set through the stock options and not use the BD features other than the tune and maybe MDS shut off. Will I be able to do that?
Sound Horn On Lock
Flash Hazards Lamps On Lock
Auto Door Lock
Auto Door Unlock
Tire Pressure Monitoring System (Disable) or Update Pressure Thresholds (28 psi to 80 psi)
Illumionated Entry Time: 0-254 seconds
Headlamp Delay Time :0-254 seconds
Accesory Delay Time: 0 - 65534 secs
Horn Chirp Duration: Short or Long
Daytime Running Lamps
Door Alert Enable
Unlock All Doors First Press
Disable Display of Clock Radio
Seatbelt Alert Minder
Sound Horn On Lock
Auto Door Lock
Auto Door Unlock
Door Alert Enable
