TDWS90
How much of a pain is it to bypass the A/C? Essentially remove it from the belt drive?
A/C is the only one that's practical for anything other than the dragstrip.
If you want to free up power, get an e-fan and ditch the clutch fan.
Water pump, alt., PS pump, A/C. That's it. lolIf you're wanting to free up power, you can do lots of things.
If you want it to be used as a daily driver, you probably shouldn't. Perhaps an underdrive pulley would be easier? There's a recent thread on it floating around.
All the belt driven things on the engine can be done away with except the alternator.
You can replace the water pump with an electric one,(not recommended)
You can bypass the a/c and power steering.
(I'm having a blank moment as to what else is on these that are belt driven.)
Sent from my SGH-T999 using Tapatalk
