Cab lights
Machria
Long Island
2015 Limited
Ecodiesel 3.0
And done......wasn't too bad thanks to all the info here. Only dropped the A pillar and no creases. Took me about 3.5 hours in all.
The sunroof def helps. I just ran a fuse tap to the box and didn't have to splice anything factory. Very happy.6e2b5cc6fff698ef18d019cc90764aed.jpg0131eb93afab6f4fe495cfb0e8219b97.jpg67cab780b11fc74cead87dc05e13c325.jpg
Where did you get the RED front hooks? Or did you just paint the black ones?
nateinva
Central Virginia
2011 1500 Laramie CC
5.7L
Somehow missed this....I painted them. Then got tired of it and went back to black. The headlights are black now too. lol
nateinva
Central Virginia
5.7L
PAINT THE WINDSHIELD BLACK!!!! :artist1:
hmmm... the red looked kinda cool.
Thanks I definitely didn't dislike it, something about it never all flowed together and it was driving me crazy. lol
BudsRam
Fayetteville, NC
2015 Ram 1500 Big Horn
Pentastar 3.6
Can anyone tell me where I can get a template for measuring out for cab lights other than fleabay or Amazon?
smoothee
St. John's, NL
Dammit now I kinda want to do this. Just don't know if it'll look silly on my regular cab, even though it's lifted a bit...and once those holes are drilled there's no turning back
cuminslvr
Pennsylvania
3.0 Diesel
I always had the orange cab lights on my 2500's. Now that I have the "Gentleman Farmer" truck I miss them. Having a hard time not modding the crap out of this rig to make it look less "formal"...:****: my ride
Badger 13
North Idaho
2013 Dodge Ram 1500
Thank you. I wished they would be an option from the factory like they are on the 2500's. Kind of a "scary" project but I have done it before on other trucks so I had an idea of what I was getting into.
smoothee
St. John's, NL
Yeah I bet. Once the first hole is drilled the nerves will hopefully calm.
Did you go with the oem kit and bulbs? I'm going with oem, just wondering if the ambers will match my headlights...or if I should get amber led bulbs
stimpy433
IOWA
I wired mine directly to the fuse box F79 which is the cab light fuse. Mine come on with lights and also with remote start. I have LED and they work fine.
Reference page 16 this thread
I'm assuming there is also a black wire that needed to be grounded??? If so, where did you attach that wire???
JB1
Houston, Texas
The black ground wire on the harness has a ring crimped on it and gets grounded to the cab. It’s a short wire so I just attached it to the cab structure behind that center upper console while it was out, I used a self tapping screw.
JB1
Houston, Texas
smoothee
St. John's, NL
Thanks! I have the fuse taps and hole saw, and I was going to ask you what you used for leds. Perfect! Did you use the same type of bulbs for both?
Reactions: JB1
