R.L.K.
- Dec 1, 2013
- 12,803
- 12,508
- Location
- Bristol , Tn.
- 2014 4X4 QC Express 6 speed auto 355 differentials
- 5.7 Hemi
This was a very easy 30 min install , simply remove the lower glove box , no tools required just release the retracting cord on the R/S and then push the sides of the glove box to free the mechanical stops and remove .
Once removed located the area to be cut out , easy to find just look @ the litle snap on door that comes with the kit . Take a good look at how the door goes on and you'll figure out what you need to cut and how . I used a box cutter with a new blade (pretty easy to cut) DO NOT LET ANY PIECES FALL IN , if they do fish them out , it goes into the impeller ( squirrel cage ) this would make lots of noise . I purchased my cabin air filter kit from www.allmoparparts.com , I think it was like $35 can't remember ...
For clarification in case someone needs it , the white area with the writing on it is the filter before I snapped the cover plate / door over the filter to cover the hole previously cut out to allow the filter to slide in just above the impeller assy.
Now just put your glove box back in and wahla your done ! Don't forget the retract string !
Lol just had to do it while in my gallery !
GO HOGS !
GO HOGS !
