Cabin Filter - Worth It? Why?
BEAST19
Can someone post a link to the kit ? I don’t have a filter I. My 2015 and would like to do the mod.
H8Train
Spoke with a technician. He suggested that it may reduce output from air/heat. I don’t think that there is enough output of cool air anyway.
Thoughts?
I didn't notice any reduction at all. The filter isn't that restrictive.
sbarron
Wasilla, Alaska
I live in a VERY dusty environment. When my filter starts to get plugged up, (about every 4 or 5 months), I get a little whistle (barely perceptible) as the system starts to pull air from around the filter rather than through it.
R.L.K.
Bristol , Tn.
2015 Big Horn 1500
Surprised to realize my 1500 did not have a cabin filter. I know MOPAR has a modification.
Any reason to consider putting this in?
I say yes , but I do a decent amount of dirt & gravel road driving especially during deer season . I went over a year prior to installing the kit from allmoparparts.com , I've definitely noticed a difference in the dust in the cab ..
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Here are a few You Tube Videos showing it ! You need a SHARP Razor knife ! Work slow. The cable that slow the opening on the glove box tie off so it is easier to retrive
H8Train
For sure work slow, if you drop a bit of plastic into the blower motor its gonna rattle around. My advice would be to heat a exacto knife up pretty good before you start cutting. Made it alot easier.
R.L.K.
Bristol , Tn.
Good idea . I heated the plastic up just a bit with a heatgun and it cuts very easy .
I do caution to heat it just a little with a heatgun !
I'd say a few minutes with a regular hair dryer on high would suffice.
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Craw,
How did you get it covered under warranty? I have the kit already. Free install works for me.
Had the dealership do it, they only charged like 60 bucks basically. So it was "professionally installed".
Craw
Western, Idaho
2013 Sport
HEMI 5.7
Thoughts?
Didn't notice a decrease at all he might be talking from a perspective view and not "I have actually done it view" It makes sense because it is passing through something but again I didnt noticed any difference other than clean air lol.
BEAST19
Where do I get the kit?
Ramnewbie
Ok, changed my cabin air filter this morning. Yes my 17 express is factory equipped with one. I tried cross referencing the Mopar part number and it crossed to a wix filter. Crossed the Fram number and the Purolator number c25858 came up. Exact replacement. I couldn't believe how dirty the old one was. It's been in there less than a year. I change my cabin air filters every year, bought one for the wife's grand caravan also, it's coming up on a year for that one.
Ramnewbie
For those that are worried about decreased air flow, my filter was pretty dirty and still working fine, deffinately tell the difference with new filter though, a/c will freeze you out.
Grant211
My 2017 ram 1500 Laramie has the cabin air filter.
Here is the picture of the part number and the cross reference for a filter.
louie217
US
5.9 360 gas
I recently did the mod and I would have to say yes. My dash gets less dust accumulated and over time the hvac system can get mildew without the filter. That happened to my previous dakota and I could’nt get rid of the smell.
This mod for 01 as well?
Sent from my SM-G928V using Tapatalk
JPT
NY
2015 Big Horn
I know the mod is there for Gen 3 Rams, but I never heard of people doing it on the Gen 2's.
pull your glove box off, and see if you see a flat rectangle right before the blower. It will look perfectly like it should have been cut from the factory...
McBroom
Denison Tx
Hemi 6.4L
Does my 2018 Ram 2500 6.4L tradesman have a cabin air filter?
glsander
