CAI whistle
DDean
K&N CAI has whistling noise that sounds like someone is literally whistling with their lips. Isnt permanent comes and goes. Normal?
xXAvroArrowXx
2014 Ram Sport CC
I'm shopping for a CAI. From what I gather its a normal sound for the K&N types especially that some refer to it as a turbo spooling sound.
Do you have CAI with metal or plastic ducts? Apparently the metal is loudest for the whistle, plastic less, and the Blackhawk dry filter version least.
Sent from my Nexus 7 using Tapatalk
DDean
DDean
Plastic tube. I dont think it sounds like a turbo either
BlkRamRt
SoCal
HEMI 5.7
did the truck have a TBS?
BlkRamRt
SoCal
HEMI 5.7
i have a K&N on my 4th gen and after the 87mm PTB it whistles loud.
popcenator
Omaha, NE
I had that happen with the last intake I had, a Chrome tube that routed down in front of the headlight. Turns out there was a small leak somewhere in the tubing.
on the move..
DDean
DDean
Sorry a bit of an idiot with abbreviations. If your refering to the sensor in which i had to drill a hole for then yes.
BigJoe1094
Somerset County, NJ
i think he is talking about a throttle body spacer.
as far as the whistle that is pretty much something that ive seen across the board with CAIs on multiple vehicles. could be a leak but its pretty common for what ive seen
popcenator
Omaha, NE
A slight whistle may be common, if it's pretty audible, I would check for a leak somewhere.
Wolfhound
CBus, OH
Make sure that the sensor that goes into the tube is facing the right way. If it is sideways it could make one hell of a whistle.
BlkRamRt
SoCal
HEMI 5.7
yeah sorry i was talking about a throttle body spacer.
WulfGang
PA
I have a strong "whistle" which I always thought sounded "like" a turbo, though not exact.
It's more pronounced if I get on the throttle.
It's VERY quiet and to most probably not even audible at a light/normal acceleration.
It's got the stock intake unit on it. So I guess I should lean more towards a hole in the intake?
Actually, I'm talking more out of a learning experience here being ATM I'm contemplating going with a VARARAM setup ASAP.
DDean
DDean
No it doesn't have a throttle body spacer. The best suggestion i've seen on here so far is checking the sensor to make sure it isn't sideways. I have a long weekend coming this week so i'll get in there and take a look around. I'll post my findings for others having this issue.
