Caliper Bracket Sandblasting
Bruinsfan
South Berwick, Maine
Needed to replace my caliper bracket on a '13 2500, got a remanufactured from RockAuto, $47, seemed pricey even from them, has anybody had luck sandblasting them and reinstalling?
buckeyexx
Ohio
2016 Power Wagon
If it’s just the bracket I see no harm in blasting it. All you have is a piece of steel with four holes in it. Two for the slide pins and two for the mounting bolts. Just cover the slide pin holes while blasting it and should be good.
