Cam/intake manifold
00 chuck
Houston
So i have been teetering on doing a full 392 stroker kit. Unfortunately not in the cards at the moment. I have been trying to find actual information on installing a 6.1 cam and intake. I have an 06 5.7.
Any info or guidance would be greatly appreciated. I am aware if im not mistaken that strokes are the same. So theoretically the cam should work no issues. As far as the intake i am not sure.
Thanks in advance
Chuck
HemiLonestar
MD
Thanks in advance
Chuck
6.1 cam and intake manifold on your stock 06 5.7 is a terrible idea. Yes the cam will bolt in, but the stroke wouldn't play into it anyway. Cam is raised in the block for that reason (some advice they took from Tom Hoover). To use a 6.1 intake you have to swap your accessories around and get rid of your clutch fan for an electric fan. Will also need adapters to mitigate the gross port mismatch as well as deleting EGR (6.1's don't use EGR). 6.1 intake is geared for more high RPM power, which isn't the hot ticket for a heavy ass truck. All that work for minimal results. Several cams out there that would do a much better job even with your stock intake manifold. If you were going with 6.1 or eagle heads then the 6.1 intake would make more sense.
Swapping in the 6.1 cam (not always the intake) was the ticket back in the early 3rd gen hemi days simply because there were no other choices
Am doing this now ..will keep u posted on issues that arise
Sent from my S60 using Tapatalk
How are you doing this on an 08 4.7.....? Or is this someone else's or you have another truck?
Patblack
Dearborn Heights Mi
The 4.7 I gave up on after three rebuilds ...by a company that kept the bird to tight or something. I got I insurance check for 6800.00 so am building 5.7 hemi from 08 dodge charger. Using 6.1 stroker kit w Diamond piistons and hellcat lifters.
.am undecided on cam yet.
.as for 4.7 it was putting out 320 hp but the tick drove me mad (piston skirt slap)
.am rebuilding myself this time n will sell it or throw on shelf for later project
Patblack
Dearborn Heights Mi
Not doing this on 4.7 but am doing swap ...putting in 5.7 in truck w same ecu.
I Hector's are same n stroker kit has 32 tooth toner ring.
HemiLonestar
MD
LOL...all available non-MDS lifters now are "Hellcat lifters". Everyone seems to think it's something special; same part number.
Can you translate that into English lol?
Patblack
Dearborn Heights Mi
Injectors are same ion 4.7 and 5.7.
Hellcat lifters have bigger diameter rollars and are not same as 5.7 lifters
00 chuck
Houston
Thank you for the input sir.
HemiLonestar
MD
You're welcome. Just do some digging, you have much better options available. I mean, there exists a 2005 quad cab that ran high 12's all motor (mid 12 with nitrous) with cam, big valve P&P stock heads all the way through 256,000 miles. When he rebuilt the engine, he stroked it (392) and now it runs mid 12's all motor. With the stock intake manifold. Google Chefred112.
JustinRam1500
