Can anyone help please with a diagram of the ABS Wheel sensor wiring? 15 Ram 1500 5.7 4x4 Crew cab. Speed sensor replaced still has light on.
CountChocula
Chicago
At my wits end.
Had the sensor replaced.
Passenger rear sensor.
Didn't change things.
ABS Light on and no 4x4 can engage. Thanks Ram for that right in the middle of a snowstorm.
Been told to replace the whole sensor harness to the front.
Hoping to avoid that.
Read a few posts about wires being pinched too tight with zips or breaks in wires and was hoping to do some tracing to see if any wires can be repaired rather than all replaced.
Thanks!
The Count
Dodge trucker
Kankakee il
Even though I have never owned anything but a dodge product I am stuck working on Ford's all day at work. .we have had a few come in with varmint chewed wiring. And it seems once a certain truck is targeted, they won't leave it alone. And they chew the same spots that we fixed each time. Others never get touched by them.
I keep seeing this one 2015 f250 where they chew the wires about at the cab to bed junction. The way the gas tank is oriented it leaves a great shelf for varmints to sit on and pig out. There is a good amount of stick out of the front of the tank ahead of the cross member and tank strap, and plenty of room between the top of the tank and underside of the bed for them to feast away.
Fatboytst
Hijacking an old post. I have replaced all four speed sensors and scanning still shows all four are bad. Where is the harness these all plugged into? Any help would be greatly appreciated.
therapywolf
