Can I get this cap?
KahneFan
Buda
No, not a 710 cap, I need a cap that goes on the end of the step - mine met a rock in a parking lot. Looks like it's just 2 screws and should be pretty easy to replace.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Is there a part number molded into the inside plastic piece?
jasonw
South Dakota
3.0L Hurricane HO
+1. If there isn't, see if you can unscrew/pop off the one on the other side to find a part number. All the ones I find look like they'd fit, but are plain black caps. My caps have "RAM" stamped into them. Are yours plain, or RAM stamped?
KahneFan
KahneFan
Buda
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
So much for that idea. Those numbers do not follow the standard FCA part numbering format. So it will probably defer to the next higher assembly which is the whole running board and is probably not orderable at that small part detail from the dealership.
KahneFan
KahneFan
Buda
And yes, it is the one with "RAM" stamped on it.
KahneFan
KahneFan
Buda
Was at the dealer for a work truck today and asked parts if they had one. They pulled out a box of them. $9/each. My over under guess was $35, so $9 seems pretty good?
Hootbro
U.S. Army Veteran
Army
Delaware
Pentastar 3.6L
$9 is not bad to restore a $450 running board set.
