Can my 2016 RAM 2500HD Tow This?
AlmostTwoGood
NC
I have a 2016 RAM 2500HD 4x4 with 6.2 short bed and I'm thinking about buying this fifth wheel, Can my truck tow it?
Just not 100% sure on all the numbers any help would be appreciated.
2016 RAM 2500 4x4 Crew Cab Specifications
Gross Combined Vehicle Weight Rating (GCWR)
19,800 lbs
Gross Truck Weight Rating (GVWR)
10,000 lbs
Gross Axle Weight Rating (GAWR)
Front: 5,500 lbs
Rear: 6,000 lbs
Gross Trailer Weight (GTW)
10,990 lbs
Max PayLoad
3,300 lbs (?) Not Sure
Axle Ratio
3.73 (?) not sure
Curb Weight
6,7,49 lbs (?) Not sure
2018 Forest River Cherokee Arctic Wolf 305ML6 Specifications
Dry Weight
8,800 lbs.
Payload Capacity
2,120 lbs.
10,990 lbs.
Hitch Weight
1,452 lbs.
Length
35.2 ft
392DevilDog
Glasgow, Pennsylvania
392 Hemi
Go to your door jamb. It will tell you your payload. And then take that from 10000 and that will give your base weight.
Report back.
Overall...the truck should have no issue. But if you want to know the numbers...i can help with that
dhay13
Think you should be ok. CAT scales will tell you for sure.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
It would be helpful to know your rear axle ratio for sure, but we'll assume 3.73s and that you have the 6.4 (not 6.2) hemi.
I would imagine your loaded, ready to camp weight will be in the 10k range.
As the others have said, its doable I believe with a good wdh, properly set up with sway control. But know once you Crest the 10k loaded trailer weight range your entering Cummins diesel territory, in my opinion anyway. I also think the stated hitch weight is on the light side for a 5th wheel
My TT is in the 6k range, loaded and I know I could do another 2k without issue. I'm sure my 17 could handle that trailer, but it'd be working in the mountains for sure. Good luck with your decision.
392DevilDog
392 Hemi
Ok. You did not come back yet. So.
Go here
Enter your VIN. Be sure to use capital letters and use the number zer0 and not the letter O.
This will tell you if you do have 3.73 or 4.10.
And get picture of your 2 door jamb stickers.
How do you set up a WDH and sway control on a fiver?
You hit the nail on the head about knowing when climbing a steep grade, especially if the OP has 3.73
Irishthreeper
Assuming you have a hemi, I have almost the same truck/5W set up you have. Truck is a ‘21 with 4.10’s. You will do fine, plan on about 9 mpg.
JerryETX
Elgin, TX
Hemi 6.4- 3:73- 6 Speed
Doable but you need to know what your rear axle ratio is.
You should be able to use this link just enter your vin at the end of it and find your truck info.
If you have the 3:73 rear axle ratio your truck will struggle going up inclines/hills. As long as you're not in a hurry your fine. 4:10 rear axle ratio will tow noticeably better.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Thanks for the correction. My error.
mvm2
