Can someone help me out?
Reed4004
5.9 Magnum
Went to start my truck this morning and my battery was dead. Jumped it off starts right up now an has a good charge but it will not stay idling soon as I let off the gas it dies. I was told to just drive it an the computer would reset so I have an it still dies when I come to a stop. Anyone have any ideas? Alternator? Battery? Any info would be appreciated. Thanks
Harley Harrold
USAF Ret. 36+ years service
Navy Badge Air Force Firefighter
Mississippi
5.7L HEMI
Try this procedure, even though you didn't touch the throttle body. This might help fix your problem.
THROTTLE BODY RESET PROCEDURE
If the throttle body has been replaced, or removed, cleaned, and re-installed, the following procedure must be performed:
a. Disconnect negative battery cable from battery. Leave cable disconnected for approximately 90 seconds.
b. Reconnect negative battery cable to battery.
c. Turn ignition switch ON, but DO NOT crank engine.
d. Leave ignition switch ON for a minimum of 10 seconds. This will allow PCM to learn throttle body electrical parameters.
e. Turn ignition switch to OFF.
f. Turn ignition switch to START position, crank engine normally.
hemihustlin
Lower Southwest Quebec
What do you mean " and has a good charge"?
Did you preform a load test on the batt and an output test on the alt?
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
if the battery is bad the truck won't run right...have it tested..
