Can you bypass the knock sensor?
mwsBlake
WV
Anyone know how to bypass the knock sensor on a 2013 Ram 1500 5.7L?
Brandon-w
Yukon
2015 Ram 1500
UNDER NO CIRCUMSTANCE DO THIS! You will wreck ****, it's there to save your engine.
Sent from my SM-G981W using Tapatalk
Burla
2010 Hemi Reg Cab 4x4
Why were you wanting to bypass this device?
M
mwsBlake
WV
So cylinder 8 is already dead no compression. Lobe on the cam is wore down is my guess. Just want to be able to turn it on long enough to drive on the trailer.
Brandon-w
Yukon
2015 Ram 1500
Oh my bad lol. She roasted. Just pull the wire off the coil and the wire off injector That way it can't fire to miss lol
M
mwsBlake
WV
Thanks ill give it a try. I plan on replacing the cam / lifters / head bolts and gaskets or just dropping a brand new motor in it.
Brandon-w
Yukon
2015 Ram 1500
It's expensive. I regret not doing a 6.2/6.4 swap on mine when my lifters went. I replaced cam, lifters and gaskets and a bunch of other stuff while I was in there. I should have swapped it. [emoji19]
M
mwsBlake
WV
So you think its better to just swap it instead of fixing it? I got a steal on the truck so im fine either way. If I would buy a brand new 5.7L would I have the same issue down the road? Anything special needed for the 6.2 or 6.4 swap beside a new motor and new wiring harness?
Brandon-w
Yukon
2015 Ram 1500
I don't even think you need new harness to Be honest. I'm Sure it's a straight swap. Im a bit of a hp junkie so any little bit of power is a bonus.
By the looks of his avatar he's swapping it into a 4.7 truck Brandon.I know there's been a few guys swap a 5.7 in for the 4.7,but i have yet to hear of anybody having much luck with the swap afterwards,and they usually end up selling the truck.On paper it should be a do able swap as the 4.7 will bolt in,and the pcms are supposedly the same,but nobody ever keeps the truck after doing the swap,lol
Brandon-w
Yukon
2015 Ram 1500
Ah that makes sense! I didn't look into that [emoji23] likely why it was picked up cheap. I'm Gonna definately follow this now.
M
mwsBlake
WV
oh no that's my old one. I bought a 2013 Ram 1500 5.7 140k today for $6500 .
