Can't get the rake out
surfnturf
hemi
I have a Daystar 2.5 level kit but it did not get all the rake out. Considering Bilstien 5100 Adjustables and/or 2.5 BL kit. Any suggestions?
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Definitely get the Bilstein 5100. That should fix your issue.
AJUSA.com has some good prices. Might want to check them out.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Few sand bags in the back good to go. :)
LB3711
Trumbull, CT
3.6L V6
weird. I can't really see mine unless I try to measure it. the 2.5 level should have really gotten rid of it
quietpeen
2021 TRX
Hellcat
Does anybody even make a 2.5 body lift? Either way that would not get rid of rake. You would have the same rake just higher
steadly2004
Lowell, NC
CTD 6.7
I just ordered all 4 for 350 $ shipped From there last night. Great prices. I can't wait for the level and upgraded ride.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
2nazt
VA
2012 1500 Big Horn
as stated the body lift would help any, just same issue higher...the bilsteins might help out though...you could also just do the front's if money is tight since there is no adjustment in the rear.
chadster21
6.7 cummins
bilsteins will fix the issue but i often wonder why people want no rake... its meant to be used as a truck lol
2nazt
VA
2012 1500 Big Horn
if you don't tow, and use it to commute then I could see how the look would be nice, I hate the nose high look once it is loaded though
S
surfnturf
hemi
Going for a Baja look. I pull a light boat or trailer from time to time but neitive rake shou;d not effect towing since I am not planning on doing anything to the rear. Will likely try the Billstiens next. May still do a BL in the future.
GreyJ
Calgary
Everyone has a different use for their trucks lol. I am building a prerunner style truck for on and offroad fun since I don't have a trailer to tow or heavy cargo. If I ever do though, my brother and dad both have diesel's I can borrow :p
chadster21
6.7 cummins
should look good. i think we have the same truck
steadly2004
Lowell, NC
CTD 6.7
I think it's more not wanting the nose slammed down, rather than not wanting any rake. I ended up with almost no rake with my Blistien install, thinking of adding spacers to add some back on the rear. At least 1 inch. That or air suspension in case I do tow it'll keep it level.
