Capacitor questions....
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I have the 2 alpine type r 12's in my truck now and they drop so low that it's making my lights dim horribly... They are wired to 2ohms. IM wanting to install a capacitor but have never done so..... Can you guys help me decide Wat size? If it will even help? Or if it is worth it?
Thanks guys..... Robb
Droid Incredible 2 on the move!!!
HKkid
Missouri
Yeah, it will definitely help. How big is your amp?
HKkid
Missouri
It goes in between the battery and the amp. I wouldn't think that that amp would do it but I guess crazier things have happened. A half farad would do it, but I would got ahead and get a 1 farad capacitor and just be done, in case you ever upgrade.
Basically it stores up some power, and then on those big hits the capacitor is able to supply that extra power without drawing it from the other components in you system.
glass3222
Central PA
For 500W, you only need a 1 farad. If you still have dimming issues, it is most likely your battery or altinator are dying. As far as wiring it in, you really cannot mess it up, there are only 2 posts on most. + and -
jhemi
wisconsin
check all grounds as well 500 watts shouldnt drop voltage that much befor i upgraded my system i was at 1800 rms and barley dimmed, make sure your power and ground wire are big enough and the ground is attached to bare metal securly my guess is wire issue som e wheres then check battery then check alt and if that doesnt fix it then do a capacitor
BIGBREW
Run a positive and negative to your cap, then a positive from your cap to your amp, and a ground from your amp to your battery.
Track3r
Bowling Green, KY
4.7 V8
Am I the only one who uses a power block? Battery > Block / Block > amp / Block > cap?
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
You can get a very nice one on the bay for pretty cheap actually I have a power acoustic one with digital gauge that was like 50 bucks and is 5 farad. Works awesome cannot dim lights no matter what.
$miley
LB3711
Trumbull, CT
3.6L V6
I have the JL 500/1 in my truck and the lights don't even flinch. What gauge wires are you using for power and ground. JL recommends at least 4 guage as for what I'm using. Do you have a good ground to bare metal? Are you hooked directly to the battery for power? Like they said above if you have all above I asked done then you need to check the battery or alternator.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I think my ground needs to be improved lol It's on bare metal but I need to ground it to the frame.... And all I run is 4 gauge wire.
jhemi
wisconsin
4 gauge is plenty big, you dont realy need to but if you ever plan on upgrading in future do the big three aswell
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
do big three, forget cap's....
ramfanatic
Banned
capacitors are just a ploy to get you to spend money they really don't do anything i have been an installer for over 30 years and never used them as they are junk
Reesycup
5.7l Hemi
X2
Caps are only a band aid for a bigger problem. If you are running the slash series jl amp a cap should not be needed. Those amps have a regulated power supply which mean that if the power light is on the amp is making max power. The power supply also allows for lower current consumption which keeps the lights from dimming. You should check your install and your charging system. I too have been installing for quite sometime and jl amps are the best and do not require a capacitor when they are properly installed.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I will agree to disagree with any of you cap haters always use and love them and the benefits they provide. I used to setup without and it was not as good.
Graygoose
Oklahoma
Convert, for now.
small
X2
I love regulated power supplies, but IMHO with nowdays technology, there's no need for caps anywhere, regulated or non.
Regulated just means the amp will do the same power, all the time...where others fall short on voltage on the rail will shut down.
Saleen5150
