Cargo bed lights not turning on
BOSTONDAN1990
Boston MA
I have a 2014 quad Cab 5.7 and I have a issue with my bed cargo lamps not turning on. When the truck is not running they will turn on with the button in the cab or with the unlock feature of the key. However when the truck is running the cargo lights will not come on at all. I have tried the button in the cab and using the key fob but neither will turn the cargo lights on while the truck is RUNNING. any help would be greatly appreciated.
Dodge 1500 4X4
Rochester, NY
Did you check the push switch in the box (rear drivers' side) if that's in the off position it will disable the bed lights, or maybe there's a problem with the switch.
BOSTONDAN1990
BOSTONDAN1990
Boston MA
what do you mean by switch in the box? I have tried the button inside the cab of the truck where the headlight knob is but other than that I don't know of any other switches.
BuschLatte420
chill water by day, drink beer by night
WNY
2022 classic tradesmen crew cab 6’4 box
5.7L NON E-TORQUE 3.92 gears 4x4
There is a button I believe or as said switch in the location this person said, I only saw it once, as I only looked once.
hunterdan
SE PA
2019 classic
On 2018+ I think they added an extra switch below the driver side bed light. If your truck is 2017 and older, it won't have that switch. My 2016 did not.
mvm2
