Catch can fault
chazerous
Oregon
So I installed my oil catch can. First time starting it up I get a check engine light. P0113, intake air temperature circuit high input. I checked the iat sensor and its connected. Anyone else have this issue and know how to resolve it? I put the original line back in to see of that helped, but I still had the fault. Thank you.
tantore
texas
some times it will take some driving and on and off cycles before the code will be erased good luck
mason mank
Waldoboro, me
I just recently installed mine as well. And had a lot of baryimg temps but no lights. So maybe a connector thats not reading right or not getting a good connection? Double check all plugs/wires again, and both ends, maybe you pulled by accident.
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
I don't know what wires you may be talking about. None of my catch cans ever had any wires associated with them?????????
Jay
After I installed mine, it collected the oil blow-by in the PCV system, and my throttle body and intake manifold were cleaner . . . but wiring that thing up was a pain in the ass.
chazerous
chazerous
Oregon
It was the iat sensor wire you have to remove to take the air intake hose off. It seems to have fixed itself. Went out and started it this morning and it was gone. I think it might just have been disconnecting the sensor that caused the fault.
BWL
Embrace the skeptisism
BC Canada
I've found on these trucks disconnecting the battery when you're plugging and unplugging stuff prevents headaches. I replaced my drivers side power window switch and it didn't work until I disconnected and reconnected the battery so that tells me the systems are pretty fussy.
Ed11
